no reading
11 years 10 months ago #141
by VE7CUP
Replied by VE7CUP on topic no reading
Tnx, Dan', Had a bad (intermitent) mic jack,, !@#$%^,, so, now pulses are good, logging 23 +/-, threshold -.1, pulses .25 and clean, sending to radmon, but still not showing up on radmon site/map, Have been sending for last 40 minutes, and still sending. ??? Ric
11 years 10 months ago #142
Replied by mw0uzo on topic no reading
Ok leave it running, I will check the server logs tomorrow to see what is being sent. Probably just a minor problem remaining
11 years 10 months ago - 11 years 10 months ago #144
Your username is VE7CUP not Ve7cup.
Last edit: 11 years 10 months ago by mw0uzo.
11 years 10 months ago #148
by VE7CUP
Looks ok now, minor problem was the user !! Hi Hi,, Also wondering how to cut the data usage down, looks like 10-15 megs per day,, and I am using this on a dedicated usb 4g modem, and the data is expensive,, for example: could the software average and send every xx minutes ? or more,, Tnx, Ric
11 years 10 months ago #149
To reduce data usuage, disable the Map with the unbloat option. The map requests new marker data every 30s. Set RadLog to upload say every 2 minutes or 5 minutes. Disabling Shared Data will also reduce data usage, although the usage is probably worthwhile for this feature and upload is only every 3 or 6 hours depending on your setup.
11 years 9 months ago #190
by VE7CUP
Wondering if anyone has actually measured the data usage under various conditions, Map/no map,, shared data etc',, I am still using close to 10 megs a day. Task Manager says only thing running is Rad Log,, Any more ideas how to get the data usage down anyone ? Tnx, Ric,,,
Time to create page: 0.208 seconds
