I need some help from you Computer experts
- FarmerDave
10 years 1 month ago #2418
by FarmerDave
I need some help from you Computer experts was created by FarmerDave
Hi, I signed up yesterday but have not been able to get the software to accept my settings and run. I downloaded the latest version and entered the correct settings. I have a GQ GMC 320 plus running on the GQ GMC software that transmits to the world wide radiation map and that is working great. I put the same settings in for the radlog software and keep getting error messages the the object is not attached to the object or somesuch mumbo jumbo. I copied the log file and will attach it if anyone can figure out how to get me transmitting. Much appreciated
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at RadLogProfessional.RadLog.button1_Click(Object sender, EventArgs e) in C:\Users\Daniel\Documents\Visual Studio 2010\Projects\RadLog\RadLog\RadLog.cs:line 894
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1022 (RTMGDR.030319-1000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/radmon.org/RadLog/RadLog.exe
Win32 Version: 4.0.30319.1002 built by: RTMGDR
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.1001 built by: RTMGDR
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
NAudio
Assembly Version: 1.7.0.15
Win32 Version: 1.7.0.15
CodeBase: file:///C:/Program%20Files/radmon.org/RadLog/NAudio.DLL
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Configuration
Win32 Version: 4.0.30319.1015 (RTMGDR.030319-1000)
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.0.30319.1015 built by: RTMGDR
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.CSharp
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
System.Drawing
System
NAudio
System.Xml
Accessibility
Microsoft.CSharp
System.Core
enabled.
For example:
<configuration>
</configuration>
10 years 1 month ago #2419
Replied by Bert490 on topic I need some help from you Computer experts
I think I know the problem. Each software collector need its own separate input port. I assume your detector uses a USB data port for the GQ software and you are trying to use the same for Radmon. Just stop the GQ software and set Radmon to the same COM port to see if that works. If you want 2 collectors to use the same Geiger counter, you will need 2 separate ports. It's easy to do for a headphone audio port (just split it like Frank has done), but I don't know of a way to do this with USB data. I would connect the audio port of your detector to the microphone input on your computer and configure Radmon for Audio interface. If you don't want to give up the microphone input, then this GQ device will provide a USB mic on a different COM port:
TOOL-081
. To use this device, set Radmon to 'GQ GMC USB serial-audio lead' and choose the appropriate COM port. In fact I use this same device on a GMC-200 feeding NETC.
10 years 1 month ago - 10 years 1 month ago #2421
Replied by mw0uzo on topic I need some help from you Computer experts
Which version are you using? V0.41 or V0.42?
It's probably best to stick with V0.41 as this is the stable version. V0.42 is a test version and introduced a lot of changes and problems to iron out. Looks like i missed a 'try-catch'
Last edit: 10 years 1 month ago by mw0uzo.
- FarmerDave
10 years 1 month ago #2424
by FarmerDave
Replied by FarmerDave on topic I need some help from you Computer experts
Thanks for the tips. I found my old detector and am now up and running
FarmerDave
FarmerDave
- FarmerDave
10 years 1 month ago #2425
by FarmerDave
Try as I might I could not get the software to run. I did install a second detector and it still would not run. I deleted the updated software and install the stable version.....It runs great.. thanks for the tip. FarmerDave
10 years 1 month ago #2426
Good to see it's working. Don't forget the LAT and LONG in decimal, with negative longitude for NA (recalling my own trials).
Time to create page: 0.212 seconds
