Password Glitch
11 years 9 months ago #241 by VE7CUP
Password Glitch was created by VE7CUP
Was wondering why my Radmon balloon was dimmed out, Checking radlog I found I wasn't logged in. Tried to log in, but get "username/password incorrect",,,mmmm, Reentered pass/user, but same thing, changed password,,, same thing,,, Anyone else had this problem ? Tnx, Ric, VE7CUP :dry:
11 years 9 months ago #243 by mw0uzo
Replied by mw0uzo on topic Password Glitch
Will check this tomorrow for you.
11 years 9 months ago #246 by mw0uzo
Hi VE7CUP
I have emailed you with your username and password. Thank you :)
If there are still problems, start your RadLog and leave it running and I will check the logs to see what might be wrong.
11 years 9 months ago #255 by VE7CUP
Replied by VE7CUP on topic Password Glitch
Still dimmed out,, What does this mean ? Ric, VE7CUP
11 years 9 months ago #256 by mw0uzo
Ah the dim map indicator means you are in 'Experiment mode' i.e. the alerts are switched off.
Go to RadLog and find the 'Enable station alerts' check box.
Toggle its status to ensure the client settings match the server settings. (They may be out of sync if I have manually disabled alerts on your station because of lots of spurious alerts)
11 years 9 months ago #282 by maredentro72
Replied by maredentro72 on topic Password Glitch
Hello and congratulations for the initiative.
I have the same problem VE7CUP, downloaded software V0.41 and when I need to check user / password me error.
Regards Alberto Italy
Time to create page: 0.174 seconds
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 15% Swap 18% CPU temp=66.2'C Uptime 17 Days
