RadLog V0.42 error.
8 years 9 months ago #3685 by James_Gy
RadLog V0.42 error. was created by James_Gy
Hi,
When I try to start logging with the V0.42 version I'm getting an "Unhandled exception error" box pop up, if I click on continue it does not start logging. I have included the details of the error. Any ideas on how to get it working?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at RadLogProfessional.RadLog.button1_Click(Object sender, EventArgs e) in C:\Users\Daniel\Documents\Visual Studio 2010\Projects\RadLog\RadLog\RadLog.cs:line 894
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2117.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/radmon.org/RadLog/RadLog.exe
Win32 Version: 4.7.2114.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.7.2053.0 built by: NET47REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
NAudio
Assembly Version: 1.7.0.15
Win32 Version: 1.7.0.15
CodeBase: file:///C:/Program%20Files%20(x86)/radmon.org/RadLog/NAudio.DLL
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.7.2102.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog b
ox.
8 years 9 months ago #3690 by mw0uzo
Replied by mw0uzo on topic RadLog V0.42 error.
Ok there are several bugs in V0.42
The stable version V0.41 is working well, so if you want to get it working straight away use that.
To try and work around your error , make sure all extra functionaliy involving COM ports is disabled, so turn off all radio control and GPS if it is activated.
What serial port mode are you using? What counter do you have?
8 years 9 months ago #3692 by James_Gy
Replied by James_Gy on topic RadLog V0.42 error.
Thanks for the reply. V0.41 is working for me but I thought I'd give V0.42 a try as I like the idea of being able to use the APRS function. All extra functions are disabled by default. I have the RH Electronics Arduino IDE Geiger counter that connects to the PC by an FTDI serial-USB adaptor.
8 years 9 months ago - 8 years 9 months ago #3693 by mw0uzo
Try using the audio interface by connecting the count pulse to the audio in of your computer with a 100nF capacitor. I know that is working with V0.42 at the moment :)
I'll check here for the error and see what's up.
Last edit: 8 years 9 months ago by mw0uzo.
8 years 9 months ago #3694 by James_Gy
Thanks, I'll stick with V0.41 for now as my pc doesn't have an audio in.
8 years 9 months ago - 8 years 9 months ago #3695 by Bert490
Replied by Bert490 on topic RadLog V0.42 error.
You can buy a USB audio mic-in dongle. GQ Electronics sells them, or E-bay, etc
links:
U-green adapter
GQ adapter
Last edit: 8 years 9 months ago by Bert490. Reason: added links
Time to create page: 0.168 seconds
Solar powered Raspberry Pi 4 server stats: CPU 63% Memory 15% Swap 17% CPU temp=64.2'C Uptime 17 Days
