radmon.org testing new server!
11 years 4 months ago - 11 years 4 months ago #1041 by mw0uzo
Trying another attempt at transferring the server to a VM today. A few silly things have tripped me up the last few attempts. The last attempt was scuppered by failure to copy the permissions of files properly. I used cp instead of the worked-out, tried and tested rsync command. I realised late into the process and abandoned it in disgust! Hopefully this attempt will work properly. If it works, I will activate the server for long enough to check all the functions then move back to the original machine.
I am very tempted to use the opportunity to move to the new server - but the main disk is not set up in RAID with another disk and the disk itself is not trusted.
Two new HDs will needed to complete the move, I will order these soon - two Seagate 2TB SSHDs. These are around £170 total so please consider donating if you use radmon.org and have not already donated. Thank you! :)
11 years 4 months ago - 11 years 4 months ago #1043 by mw0uzo
Ok it works! Back on the original server now. The difference is huge (10x+ speedup for time consuming tasks?).The graphs on the map markers are drawn instantly. The detailed graphs on the userpage are drawn within a second or two! Success! This will allow on demand drawing of detailed graphs, automatically updated say every 10m/30m or whatever seems sensible.
11 years 4 months ago #1044 by mw0uzo
HDs ordered.
11 years 4 months ago #1048 by Frank
Everything running ok here. I see a flat line gap in my readings, was checking the forum for service interrupts, didn't see anything lately unless I missed it. Rechecked my log and didn't see any errors at all going back into 4/11 but guessing it was some PC work going on. :)
11 years 4 months ago - 11 years 4 months ago #1050 by mw0uzo
Thanks for the report, the new server was not on for very long to avoid a big gap in everyone's readings. It was really fast! The new HDs should arrive on Tuesday, so maybe can get it running and live next week!
11 years 4 months ago #1051 by Frank
Yup, I see that now and was checking others and see the same, small gap was there and it was. Wanted to make sure it wasn't my pc having issues. B)
Time to create page: 0.178 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 16% Swap 18% CPU temp=66.7'C Uptime 17 Days
