How long before 'dead' stations dissapear from the map?
7 years 2 weeks ago #4647 by Simomax
Actually, you can delete datapoints from your history, up to a week before. In Radlog on the Radmon.org tab, you can choose to delete data above any value for the last 1-168 hours.
Do you know if this alters the data that has already been uploaded to Radmon? I.e. I play about for an hour with some samples and the count is all over the place. That is being uploaded to Radmon every minute. I then go and delete the last hour of data. Does that just delete it locally or both locally and on the Radmon site too? It's not a feature I have ever used before.
7 years 2 weeks ago #4649 by g346342
The server should just ignore the 0 and wait for the next update.
This is wrong
30,32,15,0,0,0,22
should be
30,32,15, 22
This first one will create a graph where the line goes down to the axis, the second will just draw a straight line between 15-22 and that is more realistic
The zeros will lower the average value too in the long term graphs and on the live map when there are more stations around it calculates an average between the stations and display the average value.
PS. I managed to clear my data. Only the trendspotting graph is still holding all data (I will give it some time)
7 years 2 weeks ago #4650 by Simomax
I understand now what you mean. I thought Radmon already did that? See here: https://radmon.org/radmon.php?function=showuserpage&user=Bond
I know the locally generated graph (from Radlog) does drop to 0 but I don't see that on any Radmon graphs.
7 years 1 week ago - 7 years 1 week ago #4666 by g346342
It does accept zeroes. That was the reason I asked how to delete my data. I can not show you the result
That year-long graph looks crazy :)
https://radmon.org/UserGraphs/Bond/graphyear.png
Last edit: 7 years 1 week ago by g346342.
7 years 1 week ago #4668 by Simomax
You are right! I never noticed that before, I thought only local (FTP) graph showed 0's. I have found this station shows the 0's: https://radmon.org/radmon.php?function=showuserpage&user=audiokaos
So with that, yes, I agree that 0's should be ignored and simply joined from the last record to the latest.
Time to create page: 0.162 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 17% Swap 17% CPU temp=65.7'C Uptime 17 Days
