Cooperation with other Radiation maps?
11 years 7 months ago - 11 years 7 months ago #619 by krzyszp
Don't worry, some of my code was created after more then 8 beers, so I'm very carefully in criticism to anybody ;)
Also, I would not discuss about Javascript as I never do anything in it ;)
Last edit: 11 years 7 months ago by krzyszp.
11 years 7 months ago #624 by mw0uzo
Ok test map available here:
http://www.radmon.org/mapjoomladev.shtml
Have a play, check the CPMs are right etc.
Lots of bugs to find.
11 years 7 months ago - 11 years 7 months ago #625 by krzyszp
"Hide r@h" button doesn't work.
"This email address is being protected from spambots. You need JavaScript enabled to view it." in detector diagram... Can you change it to "Radioactive@Home sensor" or link to project? "This email address is being protected from spambots. You need JavaScript enabled to view it." is no link nor name.. ;) - I know, it's little detail... ;)
Also, clicking on sensor move it a bit on map.
11 years 7 months ago - 11 years 7 months ago #627 by mw0uzo
Is there a userpage for radioactive@home stations with graphs etc. would be better than the link to the blank userpage.
Yep, I can change This email address is being protected from spambots. You need JavaScript enabled to view it. to a proper link, text etc
'Hide r@h' works here on 2 pcs - check again?
Last edit: 11 years 7 months ago by mw0uzo.
11 years 7 months ago #628 by krzyszp
There is two main links to our site:
http://radioactiveathome.org/boinc/ - this is main web site
http://radioactiveathome.org/map/ - this is a link to our map.
Also, every detector on our map have a link to their host details (including map) like my one:
http://radioactiveathome.org/boinc/show_host_detail.php?hostid=12521
Where hostid is also provided by script (as far as I remember).
11 years 7 months ago #647 by Frank
Was this all the uRad stations plotted? on that map itself, there are more stations that whats shown here. There is a uRad station here in Massachusetts but not showing up on our map? Just wondering, looks good thou. Bet it would be too much if we had Radmon, uRad, Radiation Network and Radioactiveathome all on the same map, but would be cool to see all the stations/detectors out there and the readings being sent.
Time to create page: 0.171 seconds
Solar powered Raspberry Pi 4 server stats: CPU 58% Memory 14% Swap 17% CPU temp=61.8'C Uptime 17 Days
