Map Key
2 years 5 months ago #6926 by FSM19
Map Key was created by FSM19
The map key doesn't appear to be working and I would like to include it on my sitehttps://www.tocsin-bang.com/observationpost.html
2 years 5 months ago #6927 by Simomax
Replied by Simomax on topic Map Key
I noticed the other day it didn't seem to be showing all the icons, now they are all gone? I'll look into it soon. Probably best/easier to just make a new one. From what I recall the current icons were sourced from Google. They are probably a hang over from when radmon.org used Google maps.
The following user(s) said Thank You: Radslug, FSM19
2 years 5 months ago #6928 by Simomax
I mean, I'll make a new one as the key on radmon.org has broken too.
2 years 1 month ago - 2 years 1 month ago #7001 by Simomax
I finally got around to fixing the map key. As it happens I had actually saved the icons back in April 2016 and never actually implemented them on my own site and was only by chance I stumbled upon them. Links to the icons are as follows (the images prefixed with e_ are the experimental mode icons):
https://radmon.org/radmon-simomax/images/map_key/normal.png
https://radmon.org/radmon-simomax/images/map_key/warning.png
https://radmon.org/radmon-simomax/images/map_key/alert.png
https://radmon.org/radmon-simomax/images/map_key/e_normal.png
https://radmon.org/radmon-simomax/images/map_key/e_warning.png
https://radmon.org/radmon-simomax/images/map_key/e_alert.png
https://radmon.org/radmon-simomax/images/map_key/dormant.png
If you have your own web server where you display the map, it would be preferable to have them served locally on your own server (it saves back and forth traffic and hot linking won't work between SSL and non-SSL sites) so I have attached a zip file that contains the icons so anyone can use them on their own website.
File Attachment:
File Name: radmon.org...cons.zip
File Size:7 KB
Last edit: 2 years 1 month ago by Simomax.
The following user(s) said Thank You: Radslug, FSM19, GuzzoTheLuke
2 years 1 month ago #7008 by FSM19
Replied by FSM19 on topic Map Key
Thanks, uploading shortly.
Time to create page: 0.149 seconds
Solar powered Raspberry Pi 4 server stats: CPU 45% Memory 14% Swap 17% CPU temp=62.3'C Uptime 17 Days
