Not seeing plots on radmon.org
10 years 10 months ago #1459
by W8HF
Replied by W8HF on topic Not seeing plots on radmon.org
Weird. I've submitted hours worth of data. I see the web page updating to the most current value each time. There must be some other issue with the format I use. Let me try manually submitting some.
10 years 10 months ago - 10 years 10 months ago #1460
Replied by mw0uzo on topic Not seeing plots on radmon.org
Have you got the user/pass correct in pyradmon config file? From the look of the logs you're still using w8hf instead of W8HF. This might partially work instead of complaining as the username check is case insensitive at the moment, but the script will break when adding the data to the database.
Last edit: 10 years 10 months ago by mw0uzo.
The following user(s) said Thank You: W8HF
10 years 10 months ago #1461
by W8HF
Found it! I had fixed the problem with the case Friday but I copied the executable to the wrong directory on the Raspberry Pi so I was still running the old version. The graphs are working fine now.
Thanks for all the help!
Time to create page: 0.116 seconds
