Detector Types
- Sonarflash
- Premium Member
- Thank you received: 15
9 years 7 months ago #2827
by Sonarflash
Detector Types was created by Sonarflash
It would be nice if, when looking at "Stations" readings, the type of detector (GM tube) was listed. Some readings are low, some extremely high. I've been using a LND7313-3 (Aware Electronics RM-80) pancake tube for years now. Some stations use an LND712, others Russian SB tubes. Knowing would be useful. Searching might be easy for some users, but not me.
Brian, Sonarflash, VA7BDG
- Electrodemente
- Thank you received: 2
9 years 5 months ago #3128
by Electrodemente
Totally agree your comments.
The kind of tube (and number if several) can explain the diferences on mesurements.
Best Regards,
E.D.
Replied by Electrodemente on topic Detector Types
Best Regards,
E.D.
9 years 5 months ago #3134
Replied by Simomax on topic Detector Types
I think it would also be a great help if it were possible to display the expected background radiation CPM or something similar. That way people with no experience of different detectors will be able to easily work out if the readings are normal or require further investigation.
9 years 5 months ago #3135
by mnrad
Replied by mnrad on topic Detector Types
I agree. In meteorology, when doing data quality control one of our QA/QC parameters is what is the value's departure from a long-term average or, say, a record high value.
- Sonarflash
- Premium Member
9 years 5 months ago #3141
by Sonarflash
Replied by Sonarflash on topic Detector Types
Somehow, blundering about in the radlog program, I managed to put my address, and e-mail on the "Station" display line. Instead, putting the GM tube type there would be an improvement if others did the same. Unfortunately, I couldn't seem to change it last night. Also, I suspect that Radlog Pro messed up my FTDI drivers while making the attempt. Had to reinstall a few things today.
