Location uptdate failed
- DanielSiebert
7 years 9 months ago #4211
by DanielSiebert
Location uptdate failed was created by DanielSiebert
Hello.
SQL query to set user location failed. Try a slightly different address, or contact admin.
best regards
best regards
7 years 9 months ago #4213
Replied by mw0uzo on topic Location uptdate failed
This feature is no longer working, as google has restricted the geocoding lookup service. Change the coordinates on your profile page instead.
- DanielSiebert
7 years 9 months ago #4214
by DanielSiebert
Replied by DanielSiebert on topic Location uptdate failed
hello,
my profile update does not work
Warning
Profile could not be saved: Username does not meet the criteria:
May contain upper-case letters
May contain lower-case letters
May contain numbers
Min length: 3
Max length: 25
my name is "DanielSiebert"
UserName (optional) is "Daniel Siebert"
I can not change that somehow. can you change my username to "Daniel-Siebert"
best regards
Warning
May contain numbers
Min length: 3
Max length: 25
best regards
7 years 9 months ago #4215
Ah ok I will fix this now.
7 years 9 months ago #4216
Ok it is now DanielSiebert
The following user(s) said Thank You: DanielSiebert
Time to create page: 0.177 seconds
