my station is working but the data not appear in the graph
2 years 9 months ago - 2 years 9 months ago #6813 by Danielgeiger
I am sending data but it does not appear in the graph
Last edit: 2 years 9 months ago by Danielgeiger.
2 years 9 months ago #6814 by DonZalmrol
Seems you are sending a value of 0 to Radmon. Could you show you're code you are using? And is the upload value correct on your end?
https://pastebin.com/ is your friend for uploading your code
2 years 9 months ago #6815 by Danielgeiger
I had tried it a few days ago and it works well.
has the following code
https://install.espgeiger.com/
2 years 9 months ago - 2 years 9 months ago #6818 by Simomax
I have just had a quick look and your counter is submitting 0's. You should check that the ESP8266 is getting a proper count from the CAJOE counter
See here:
You can use the 'Status' page on the ESPGeiger to check if your counter is working poroperly regardless of it's submission to radmon.org. Go to the ESPGeiger main page and press the 'Status' button and there you can see if it is counting properly. If you are getting 0's on the status page, it will be sending 0's to radmon.org.
Last edit: 2 years 9 months ago by Simomax.
2 years 9 months ago #6819 by Danielgeiger
2 years 8 months ago #6835 by FSM19
Have a look at your Control Panel and check that you have the correct password set, and that it matches the password in your hardware. I don't have the same gear as you so don't  know your firmware settings. Your CP should look like this (except of course the station name and password, I have obscured my password for obvious reasons).
Time to create page: 0.163 seconds
Solar powered Raspberry Pi 4 server stats: CPU 55% Memory 15% Swap 17% CPU temp=63.3'C Uptime 17 Days
