High readings in Northern Minnesota
11 years 3 months ago #1183 by Bert490
Hi Icebox
Your sensor readings have doubled recently into the Warning range. Is there a change in your environment or in your sensor?
[copy to PM]
10 years 10 months ago #1462 by Bert490
Hi Icebox:
Your station has recently returned to more normal readings. Have you changed the sensor in some way? Your readings were very different between Sept 9 and Oct 16, but similar increases were not seen on other sensors in the area. A post to the forum would help clear this up. I tried to PM you but your user name no longer appears in the valid list.
Time to create page: 0.136 seconds
Solar powered Raspberry Pi 4 server stats: CPU 63% Memory 14% Swap 17% CPU temp=63.7'C Uptime 17 Days
