Jump in Dose/CPM at late night?
8 years 8 months ago #3746
by Onions
I am Onions and I approve this Message
Jump in Dose/CPM at late night? was created by Onions
Hi all,
Last night I noticed something very interesting. about 2130MST my RadMon Readings went off the chart and starting blowing up my phone (IoT app!)- CPM jumped to 4200 and 25µSv-- Nearly 400% above (maxium) basline measures.
this lasted from about 2130MST to about 0600MST (UTC 0430- 1300) had spikes ranging from 1300CPM to almost 4200 CPM- the main differences being this time around, I moved location of my radios (I work HF and VHF), my counter about 8" to the right of it's current location on the ledge of the window (working on getting a self contained unit) and my window has a new feed through in it. I know atmospheric conditions and soil temp/ saturation is a large facor in radon- however having had the station monitoring for will over a day at this point, similiar conidions aevery night (about 30° and no precip, about 30-40% Humidity). This is very interesting, and I was wondering if anyone had any ideas about this?
Thanks
PS I will have pictures soon- just need to get them off my phone
Thanks
8 years 8 months ago #3751
by Radslug
Replied by Radslug on topic Jump in Dose/CPM at late night?
That's quite a spike! Has it continued & does it happen when the detector is moved away from other equipment?
8 years 8 months ago #3752
by Onions
Interestingly enough it has not. I was going to run a couple of tests tonight; putting my lead solder near it (I had to file some off from a PL-259) to see or if I move it away if it will spike again. I know another major difference was I wrapped the positive lead of the tube in Electrical tape; knowing most adhesives release x-rays and photons (try undoing a band- aid or other stickers quickly in the dark [triboluminescence], you'll see) and maybe? there was a factor there. Will double check.
as far as moving it away from other equipment; I have not tried. I know this happened as I moved it closer (it has not moved position since) to my computer and Radio/power supply. How ever, this spike has not been seen since. not even the Norway/ Sweden stations were showing that kind of spike, from what I am seeing.
Replied by Onions on topic Jump in Dose/CPM at late night?
Time to create page: 0.128 seconds
