New setup
6 years 8 months ago #4983 by FSM19
New setup was created by FSM19
I am working on a new setup, so there may be no readings, or strange readings for the next few days. The idea is to have an external probe based on a Banggood unit. So far I have just tested the counter and it seems fine and stable. Wish I could say the same about the display, which is all over the place, probably just a question of re-soldering. Then I need to get it to connect with Radmon via ethernet. The display and ethernet are via Arduino nanos.
6 years 7 months ago #4998 by mw0uzo
Replied by mw0uzo on topic New setup
I've got a pack of nanos waiting to be used. What ethernet board are you using? I'd like to interface an ethernet or wifi board with the arduino. (I understand the ESP wifi boards have quite a decent microcontroller in them already, like used in BroHogans RadMon kits. So this might not make so much sense)
6 years 7 months ago #5001 by FSM19
Replied by FSM19 on topic New setup
ENC28J60
Time to create page: 0.119 seconds
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 15% Swap 18% CPU temp=65.7'C Uptime 17 Days
