Gradual count increase at FSM19
5 years 5 months ago #5687 by mw0uzo
Use one of those filtered mains leads with surge protections etc? Put a few 100nF caps across the supply output?
5 years 5 months ago - 5 years 5 months ago #5689 by FSM19
I'm going offline for a day or so while I design and build a new linear power supply with good in and out filtering.  Well that seems not to have worked!
Still getting high peaks.
Last edit: 5 years 5 months ago by FSM19.
5 years 5 months ago #5693 by FSM19
Things seem to be better, but for some reason counts are not showing up on Radmon!
5 years 5 months ago #5694 by mw0uzo
Is everything working OK now? I can see your graphs starting to update. They redraw at a set interval (except for the one on the map, that is redrawn after every new reading) so give them time to update.
5 years 5 months ago #5695 by FSM19
Everything is fine now, thanks. I built a new PSU with loads of smoothing, and added ferrites on my probe, ethernet and mains cables. The failure in uploading was due to a faulty network socket.
5 years 4 months ago #5701 by FSM19
I really don't believe it, everything runs fine for days, and suddenly again more spikes! All I can think of is mains spikes. We are having pretty awful weather at the moment, and in a rural area the power can be inconsistent. Monitoring the other day I found that the nominal 230V varied between 218 and 245!
Time to create page: 0.243 seconds
Solar powered Raspberry Pi 4 server stats: CPU 65% Memory 15% Swap 18% CPU temp=64.7'C Uptime 17 Days
