How to send $value from home asstistant entity
3 years 5 months ago - 3 years 5 months ago #6417 by SeByDocKy
Ok I found the solution. You don't have to use a shell_command since templating is not working (properly) but use a binary_sensor command line. So in your binary_sensors.yaml
########## radmon.org ########
- platform: command_line
  command: 'curl -s "http://radmon.org/radmon.php?function=submit&user=xxxxx&password=yyyyy&unit=CPM&value={{(states.sensor.your_CPM_entity.state|int)}}"'
  payload_on: 'OK<br>'
  scan_interval: 60
Last edit: 3 years 5 months ago by SeByDocKy.
3 years 3 months ago - 3 years 3 months ago #6472 by SeByDocKy
HA is going to change how to define a command_line binary sensor. Now in your configuration.yaml
command_line:
   - binary_sensor:
       command: 'curl -s "http://radmon.org/radmon.php?function=submit&user=xxxxxx&password=yyyyy&unit=CPM&value={{(states.sensor.yourCPMsensor.state)}}"'
       scan_interval: 60
Last edit: 3 years 3 months ago by SeByDocKy.
3 years 1 month ago - 3 years 1 month ago #6550 by cougar
Hi,
I just integrated my ESPhome Geiger counter with radmon.org. There is RESTful Sensor that can be used for that which is somewhat more secure than using command. For me it is just easier to read in config. Put something like this into the configuration.yaml or any package file:
sensor:
   - platform: rest
     unique_id: "798adf5b-bfd9-4bd6-a09d-e5c1f8fff518"
     scan_interval: 60
     resource: http://radmon.org/radmon.php
     params:
       function: 'submit'
       user: 'xxxxxxxx'
       password: 'XXXXXXXX'
       unit: 'CPM'
       value : "{{ states('sensor.geiger_counts_per_minute')|int(0) }}"
Last edit: 3 years 1 month ago by cougar.
3 years 1 month ago #6556 by SeByDocKy
I tried a pure ESPhome solution.... (via http_request.get) but I find this solution not super stable (the ESP32 rebooting every 15min)
2 years 5 months ago - 2 years 5 months ago #6914 by OH8EFI
This will run in ESP locally? I tried http_request but the ESP reboots every time it tried it. I was able to http_request.send POST to GMCmap and it works fine. What should I use as an unique identifier?
EDIT: Got the http_request working
Last edit: 2 years 5 months ago by OH8EFI.
Time to create page: 0.178 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 15% Swap 17% CPU temp=65.7'C Uptime 17 Days
