Forum
Alerts, Detections and Station Updates
Station Updates
Updates to Radspod stations
Simomax
Offline
Moderator
Nuts about radioactive everything!
Thank you received: 321
3 years 1 month ago - 3 years 1 month ago #6528
The Radspod stations have been renamed as follows:
radspod_suburb is now radspod_one
radspod_north is now radspod_two
I will probably keep this naming convention for any further counters that I deploy, so the next would be radspod_three.
radspod_two has come home for a bit as it can no longer live where it was at North Blackpool. It needs a new enclosure and then at some point in the not too distant future I will redeploy this to a different location. For now it is sitting on a shelf in my office. Strangely, this counter (GK Radmon) has always seemed to count a little high. I would get 22 CPM on one counter but more like 29 CPM with the GK Radmon. I will try swapping tubes. Maybe the tube is more sensitive than others? It's an SBM-20, so that would be slightly odd. Or maybe the HV PSU is a little high. I should test. The code running is tried and time tested (same core code I have used time and time again) so I highly doubt that.
Last edit: 3 years 1 month ago by
Simomax.
Forum
Station Updates
Time to create page: 0.122 seconds
Solar powered Raspberry Pi 4 server stats: CPU 63% Memory 15% Swap 17% CPU temp=64.7'C Uptime 17 Days
