Submit data to radmon.org with node-red
3 years 1 week ago #6569 by Juzzie
The Achievement.
After a long series of favourable accidents, I have managed to get my rpi 4B up and  running as a local server and database for my environmental monitoring data - all powered by solar.
This miracle has been made possible with the use of nginx server, node-red, influxdb, Grafana, and my very limited intellect.
The Problem.
Over the years I have bought quite a number of geiger counter kits from brohogan (https://sites.google.com/site/diygeigercounter/) and currently am using 3x gk-b5 + gk-wifis and a gk-radmon to submit my data to radmon, thingspeak, and, now, my own database via mqtt.
So, recently I decided to see if I could magick a 5th counter into the fray via USB connected directly into the rpi server, as a bit of fun, and have mostly succeeded. - CPM, Dose, Vcc through USB0 > node-red > influxdb, thingspeak, Grafana. BUT - I cant work out how to send the CPM to radmon.org using node red. I think it's down to adding CPM payload to radmon submission htpp string, or some such.
Would someone be so kind as to point me in the right direction?
3 years 1 week ago #6570 by Simomax
I know nothing about code red so my help is very limited; did you read the pages on the Node red HTTP recipes page? (Here:  https://cookbook.nodered.org/http/ )
I had a quick look through, and if I am understanding your issue correctly (can't pass CPM over to http thingy) the answer may be on the set query string parameters link on the recipes page. What I am understanding from a (very) little reading it seems you have to set the query and then inject it into the URL, or something like that.
3 years 1 week ago #6574 by Juzzie
Thank you Simomax. Followed the link and it looks promising. Working on it now...The terminology is counter intuitive - I wasn't aware that posting data to my radmon station was a "query".
3 years 1 week ago #6576 by Juzzie
I got it working, thank you once again simomax :-}
3 years 1 week ago #6577 by Simomax
Brilliant! Well done.
Time to create page: 0.140 seconds
Solar powered Raspberry Pi 4 server stats: CPU 62% Memory 14% Swap 17% CPU temp=63.7'C Uptime 17 Days
