Raspberry Pi stability
2 years 1 month ago #7006
by jnissen
Raspberry Pi stability was created by jnissen
I have been running a Pi to log data for years. I have noticed the past year or so that the site will go offline more and more often, I have changed physical location a few times but the same network WiFi connection. The GMC counter never seems to be offline and in all cases the Pi seems to be the issue.
Any hints to get better service? Thinking of changing the SD card and moving to a wired connection on the Pi. I will soon have plenty of wired access as I have a new network switch with a few open ports. Any other suggestions?
2 years 1 month ago #7007
Replied by Simomax on topic Raspberry Pi stability
It is very possible the SD card may need replacing. SD cards aren't as hardy as SSDs or conventional hard disks and each sector/block has a finite write cycle, so once it has been written to so many time it will fail if that sector/block is written to again. Replacing the SD card may just solve your issue. I have a old Pi running as a security camera and the card failed in that a few years ago. I replaced it with a good make (Sandisk or Kingston or some other decent make) and it hasn't failed yet, but I am expecting it to go again at some point.
If the Pi is caching on the SD card this can accelerate the deterioration as it will be doing lots of writes. The same goes for anything that writes to the card a lot. Log files, databases and other things like that can impact SD card life.
Moving to a wired ethernet connection is always a good idea if you can do that easily.
Andreas Spiess has just done a video on this:
1 year 10 months ago - 1 year 10 months ago #7049
by jnissen
Replied by jnissen on topic Raspberry Pi stability
Finally biting the bullet. Had a spare Pi in a drawer so I have the latest software downloading now. Hopefully my detector will be back online soon. Fresh SD card and will try a direct wired connection as well.
Update - Just set the Pi to READ only and use the built in background file system. It writes to RAM as opposed to the SDCARD now. Only needed to be careful to only turn on the READ ONLY section after I was sure everything was working properly. I also plugged in the Pi so the two should let this setup run for a while before touching it again! Thanks all.
Last edit: 1 year 10 months ago by jnissen.
1 year 10 months ago #7063
by jnissen
Just an update... several weeks in and solid performance. My old setup would have gone offline by now. Thanks all.
1 year 6 months ago #7174
by jnissen
Several months in and the site has only gone offline once. We had some strange power off/on cycles and there may have been an issue with the Rasberry Pi starting up. In general if you can use a read only file system and use a virtual memory system then all the Pi scratch pad data is only written to RAM and not to the SDCARD. Seems to be working as the SDCARD is holding up well.
The following user(s) said Thank You: GuzzoTheLuke
Time to create page: 0.142 seconds
