Change to W8HF station
10 years 10 months ago #1502
by W8HF
Change to W8HF station was created by W8HF
Last night I added a second detector to my setup. I now have a GMC200 with an M4011 tube attached to the same Raspberry Pi as the MightyOhm with the SBM-20.
I am running a custom program written in the Go programming language and modified it to read the GMC200 and add the result with the MightyOhm. I adjusted my conversion by summing the inverse of the M4011 and SBM-20 conversion factors so the uS/h should be the same.
Not sure anyone noticed but wanted to account for the jump in raw CPM readings.
I also adjusted my alert and warning levels though I had a few bad points (low) my first live test run.
I eventually want to move one of the detectors outside with an air filter. When that happens I'll request a new ID and post those results independent of my indoor readings.
10 years 10 months ago - 10 years 10 months ago #1539
by W8HF
Replied by W8HF on topic Change to W8HF station
I can't leave well enough alone! They had a great eBay sale on new GMC-200 counters ($45) so I added a couple to my setup removing the MightyOhm for now. I have the three GMC-200s stacked on top of each other and I'm locally logging coincidence detections. I'm working to setup an outdoor setup with a HEPA filter and will move one out there or use the MightyOhm in that setup.
The change in configuration explains the slight bump yesterday.
I noticed today the new GMC-200 are back to $65 on eBay from gq_instruments.
It was a great deal while it lasted considering that included the tube, power supply and the USB adaptor to interface it to a PC.
Last edit: 10 years 10 months ago by W8HF.
Time to create page: 0.113 seconds
