Alert Link Overload by Low Readings
- Sonarflash
- Premium Member
- Thank you received: 15
8 years 7 months ago #3841
by Sonarflash
Alert Link Overload by Low Readings was created by Sonarflash
Bond, in Estonia, has his alert level set too low, so he constantly fills up the Alert link with low readings. Perhaps nobody else cares that we are seeing alerts for 23 or 30 CPM?
8 years 7 months ago #3842
Replied by Bert490 on topic Alert Link Overload by Low Readings
The alert level for Bond in Estonia is now set at 65. Thank you, Bond for correcting this. Now, we still have:
- LP in Norway currently reading 4241630000 CPM. Experiment mode blocks alerts but the map is 'polluted'. It clearly is not working and PMs have been sent with no response. Admin intervention may be warranted.
- PA3GET in Netherlands, intermittently 7500 CPM. PM sent.
8 years 7 months ago - 8 years 7 months ago #3843
Replied by mw0uzo on topic Alert Link Overload by Low Readings
Ok I figured out why this is happening. Some users are sending the CPM data as a string: eg value="20" instead of value=20. This confuses the limit checking code!
I have modified the code to try to fix this problem. Let's see what alerts come up in the next few hours.
Last edit: 8 years 7 months ago by mw0uzo.
Time to create page: 0.143 seconds
