× For discussion of news and events happening around the world right now
Wuhan coronavirus
6 years 6 months ago #5099 by mw0uzo
Replied by mw0uzo on topic Wuhan coronavirus
Report from Iranian nurse - 8 deaths in one evening, variety of ages
Invalid consumer key/secret in configuration
6 years 6 months ago #5100 by mw0uzo
6 years 6 months ago - 6 years 6 months ago #5101 by FSM19
Replied by FSM19 on topic Wuhan coronavirus
There are several problems with mass testing. One is to have a suitable test method, one of the tests currently in use is known to be faulty. Second there is no such thing as an infallible test, even using the most advanced techniques they will probably only detect 95% of cases. Next is the production of adequate quantities of the test reagents, which is a hugely specialist task. Also tests have to be conducted by trained personnel, that means doctors or nurses or laboratory technicians or a combination, depending on the test type; the NHS is already stretched beyond capacity in many places. It is far more effective in epidemiological terms to target those at highest risk and their immediate contacts. BTW my first job was in immunology and microbiology.The diagnosis of COVID-19 must be confirmed by reverse-transcription polymerase chain reaction (RT-PCR) or gene sequencing for respiratory or blood specimens, this takes several days. First it involves tissue culture of the suspect material to produce enough virus for testing, this is tricky as sputum samples will be heavily contaminated with other organisms and these need to be controlled. The quickest testing I can imagine would be 3-4 days and possibly longer. Another method would possibly be immuno-fluorescence microscopy, I know this has been used as a research tool, but it is very labour intensive; I have seen images showing the techniques has been used. However I think that this latter is unlikely to be used as a field test.
Last edit: 6 years 6 months ago by FSM19. Reason: Update.
6 years 6 months ago - 6 years 6 months ago #5102 by mw0uzo
Iranian President Hassan Rouhani has been infected with coronavirus
Last edit: 6 years 6 months ago by mw0uzo.
6 years 6 months ago #5103 by FSM19
https://www.worldometers.info/coronavirus/
6 years 6 months ago #5104 by mw0uzo
Fontana: "Emergency in Lodi, 51 hospitalizations"
"Unfortunately, another emergency broke out in Lodi last night. In Lodi suddenly yesterday afternoon there was a crowding of hospitalizations: 51 serious hospitalizations of which 17 in intensive care. Lodi does not have a sufficient number of intensive care for which they were transferred to other intensive care in the region ". This was explained by the president of Lombardy Attilio Fontana all'Aria who pulls up La7 talking about coronavirus. "If you laughed less at the mask and looked at the problem more carefully
I think it would be wise," he added.
https://tg24.sky.it/cronaca/2020/02/28/coronavirus-italia-notizie.html?intcmp=hp-tg24_hero_main-title_null#
It will only take ICUs to be overwhelmed in several hospitals for the death rate to increase significantly.
Time to create page: 0.693 seconds
Solar powered Raspberry Pi 4 server stats: CPU 70% Memory 17% Swap 18% CPU temp=68.1'C Uptime 17 Days
