× For discussion of news and events happening around the world right now
Tunnel collapse at Hanford ... and leaking of double shell tank!
9 years 4 months ago - 9 years 3 months ago #3232 by mw0uzo
http://www.king5.com/news/local/hanford/tunnel-collapses-at-hanford-no-radiation-released-officials-say/438227872
Last edit: 9 years 3 months ago by mw0uzo.
9 years 4 months ago #3235 by Simomax
Replied by Simomax on topic Tunnel collapse at Hanford
Dahboo7 over on Youtube has some more info with regard to this. Unfortunatly towards the end the audio screws up but is still worth a watch.:
If I find out any more info not yet covered, I'll be sure to post here.
9 years 4 months ago #3238 by Simomax
Some more on this: http://www.fukuleaks.org/web/?p=16292
The tunnel is 109 meters long and houses 8 rail cars holding highly radioactive equipment. The bulk of the contaminated equipment are waste concentrators. These were used to separate out remaining uranium and plutonium from nitric acid. The liquid was sent back to be reused in the extraction process while the sludge was sent to the waste processing facilities. These concentrators are radioactive and may contain residues on the equipment. One concentrator was logged as having 40,000 curies of radiation when it was placed in the tunnel.
9 years 3 months ago - 9 years 3 months ago #3241 by Simomax
Some more info:
Hanford: Tunnel Collapse May Have Gone Unnoticed for Days, Releasing Radiation Into Open Air
Last edit: 9 years 3 months ago by Simomax. Reason: Remove dead video link
The following user(s) said Thank You: Gamma-Man
9 years 3 months ago - 9 years 3 months ago #3249 by Simomax
Officials warn of more collapses at US nuclear site — “High spikes” in radiation levels recorded — Expert: Plutonium could go airborne — Major concern over radioactive releases — Gov’t delays revealing data to public
http://enenews.com/alert-officials-warn-of-more-collapses-at-us-nuclear-site-high-spikes-in-radiation-levels-recorded-expert-plutonium-could-go-airborne-major-concern-over-radioactive-releases-govt-d
I'm not sure why the video's I have previously posted are now unavailable. I'll try and contact the youtube user and see why. I have emailed the youtube user to see why they are not available.
Last edit: 9 years 3 months ago by Simomax. Reason: Plumbs are smart!
9 years 3 months ago #3256 by Simomax
"Everybody's Freaked" - Washington Nuclear Facility Admits Second Radiation Leak, Workers Contaminated
Just under two weeks since the emergency at the Hanford nuclear facility in Washington state (following a tunnel collapse), NBC's local affiliate King5 reports Hanford’s owner, The U.S. Department of Energy, is scrambling to deal with a second emergency - signs have emerged that a massive underground double shell nuclear waste holding tank may be leaking.
http://www.zerohedge.com/news/2017-05-20/everybodys-freaked-washington-nuclear-facility-admits-second-radiation-leak-workers-
The following user(s) said Thank You: mw0uzo, Juzzie
Time to create page: 0.146 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 17% CPU temp=62.3'C Uptime 17 Days
