Connecting Geiger Counter for Arduino and Raspberry Pi to radmon.org
7 years 7 months ago - 7 years 7 months ago #4258 by pilovis
NOTE: the geiger tube J305β is UV light and alfa ray sensitive, to avoid false readings you need to completely cover it with some black electrical tape,
eventually put a thin layer of copper sheet to protect it from EMI.
This device is compatible with many tubes working from 350V to 1000V
tube chosen: J305β Geiger Tube
Specifications:
Manufacturer: North Optic
Radiation Detection: β, γ
Length: 111mm
Diameter: 11mm
Recommended Voltage: 350V
Plateau Voltage: 360-440V
Sensitivy γ ( 60 Co): 65cps/(µR/s)
Sensitivy γ (equivalent Sievert): 108cpm / (µSv/h)
Max cpm: 30000
cps/mR/h: 18
cpm/m/h: 1080
cpm/µSv/h: 123.147092360319
Factor: 0.00812037037037
suggested H.T. tube supply circuit from manifacturer:
Tutorial and product page:
https://www.cooking-hacks.com/documentation/tutorials/geiger-counter-radiation-sensor-board-arduino-raspberry-pi-tutorial
This device does not use serial communication to read measurement data!
My Arduino code to measure uSv/h, send it to stdout and to activate LCD display and bargraph
Prerequisites: arduPi library for Raspberry
measure.c
 *  ------Geiger Tube board (Arduino Code) Example--------
 *  Explanation: This example shows how to get the signal from the Geiger Tube
 *  in Arduino, we use one of the Arduino interrupt pins (PIN2).
 *  We count the time (ms) between two pulses of the Geiger tube.
 *  Copyright (C) 2011 Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 2 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version:		0.3
 *  Design:		Marcos Yarza, David Gascon
 *  Implementation:	Marcos Yarza
 *  Version     0.4
 *              20140420 by circulosmeos for RPi compatibility
 *              circulosmeos.wordpress.com
 *  modified by P.M. Lovisolo Italy - http://forum.49v.com
// include the arduPi library code:
#include "arduPi.h"
// include the LCD library code:
#include "LiquidCrystal.h"
// Threshold values for the led bar
#define TH1 75
#define TH2 150
#define TH3 250
#define TH4 400
#define TH5 600
// define geiger tube Conversion factor (cpm * conversion factor  = μSv/h)
// for J305By geiger tube
//#define CONV_FACTOR 0.00812
// for SBM-20 geiger tube (1/361)
#define CONV_FACTOR 0.00277
// Variables
int ledArray [] = {10,11,12,13,9};
int geiger_input = 2;
long count = 0;
long countPerMinute = 0;
long timePrevious = 0;
long timePreviousMeassure = 0;
long countPrevious = 0;
float radiationValue = 0.0;
void ledVar(int value);
void countPulse();
void setup(LiquidCrystal *lcd){
  pinMode(geiger_input, INPUT);
  digitalWrite(geiger_input,HIGH);
  for (int i=0;i<5;i++){
    pinMode(ledArray[i],OUTPUT);
  // test led array ON
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  pinMode(11, OUTPUT);
  digitalWrite(11, HIGH);
  pinMode(12, OUTPUT);
  digitalWrite(12, HIGH);
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  pinMode(14, OUTPUT);
  digitalWrite(14, HIGH);
  pinMode(15, OUTPUT);
  digitalWrite(15, HIGH);
  pinMode(9, OUTPUT);
  digitalWrite(9, HIGH);
  //set up the LCD\'s number of columns and rows:
  lcd->begin(16, 2);
  lcd->clear();
  lcd->setCursor(0, 0);
  lcd->print("Radiation Sensor");
  lcd->setCursor(0,1);
  lcd->print("Board - 2019 -");
  delay(3000);
  lcd->clear();
  lcd->print("Counts*minute");
  lcd->print("microSv*hour");
  delay(3000);
  //for (int i=0;i<5;i++){
  //  delay(200);
  //  lcd->scrollDisplayLeft();
  //delay(500);
  lcd->clear();
  lcd->print("- www.49v.com -");
  lcd->print(" P.M. Lovisolo ");
  delay(3000);
  //led array off
  digitalWrite(10, LOW);
  digitalWrite(11, LOW);
  digitalWrite(12, LOW);
  digitalWrite(13, LOW);
  digitalWrite(14, LOW);
  digitalWrite(15, LOW);
  pinMode(9, OUTPUT);
  digitalWrite(9, LOW);
  lcd->clear();
  lcd->print("CPM=");
  lcd->setCursor(4,0);
  lcd->print(6*count);
  lcd->setCursor(8,0);
  lcd->print("counts");
  lcd->print(radiationValue);
  lcd->setCursor(7,1);
  lcd->print(" uSv/h");
  attachInterrupt(2,countPulse,FALLING);
void loop(LiquidCrystal *lcd){
  if (millis()-timePreviousMeassure > 60000){
    detachInterrupt(2);
    countPerMinute = 1*count;
    //countPerMinute = count/10;
    radiationValue = countPerMinute * CONV_FACTOR;
    timePreviousMeassure = millis();
    //Serial.print("cpm = ");
    //Serial.print(countPerMinute,DEC);
    //Serial.print(" - ");
    //Serial.print("uSv/h = ");
    //Serial.println(radiationValue,4);
    lcd->clear();
    lcd->print("CPM=");
    lcd->print(countPerMinute);
    lcd->print(radiationValue,4);
    lcd->print((int)radiationValue);
    //fprintf(stderr,"CPM ");
    //fprintf(stderr,"%d\n",countPerMinute);
    fprintf(stderr,"%f",radiationValue);
    fprintf(stderr," uSv/h\n");
    //led var setting
    if(countPerMinute <= TH1) ledVar(0);
    if((countPerMinute <= TH2)&&(countPerMinute>TH1)) ledVar(1);
    if((countPerMinute <= TH3)&&(countPerMinute>TH2)) ledVar(2);
    if((countPerMinute <= TH4)&&(countPerMinute>TH3)) ledVar(3);
    if((countPerMinute <= TH5)&&(countPerMinute>TH4)) ledVar(4);
    if(countPerMinute>TH5) ledVar(5);
    count = 0;
    delay (60000);
void countPulse(){
  //detachInterrupt(2);
  count++;
  //while(digitalRead(2)==0){
  //attachInterrupt(2,countPulse,FALLING);
void ledVar(int value){
  if (value > 0){
    for(int i=0;i<=value;i++){
      digitalWrite(ledArray[i],HIGH);
    for(int i=5;i>value;i--){
      digitalWrite(ledArray[i],LOW);
  else {
    for(int i=5;i>=0;i--){
int main (){
    // initialize the library with the numbers of the interface pins
    // AFTER WirePi has been initialized (!)
    LiquidCrystal lcd(3,4,5,6,7,8);
    setup(&lcd);
    while(1){
        loop(&lcd);
    return (0);
Note:
modified for the SBM-20 tube, if you want to use the J305B tube, you need to comment-out the SBM-20 CONV_FACTOR section and remove comment in the J305 section this way:
//#define CONV_FACTOR 0.00277
compile the code for Raspberry:
g++ -lrt -lpthread measure.c LiquidCrystal.cpp Print.cpp arduPi.cpp -o measure
setting permission to file:
chmod 755 measure
to launch file from Raspberry console (test):
sudo ./measure
My Raspberry scripts (all Bash):
prerequisites:
sudo apt-get install bc
This is the main script I programmed to start measuring uSv/h, to display data on the LCD and to save measurements in a csv temporary file.
The csv file is regenerated (empty) at each reboot since I don't want a huge file and also because I use MySQL to store all data.
If you are too much worried about writing data too frequently to the internal SD card, you can use a ramdisk or an external USB drive.
print_rad2csv.sh
#!/bin/bash
measure 2>&1 | awk '{ print strftime("%s %Y-%m-%d %H:%M:%S"), $0; fflush(); }'  | sed -e 's/\s\+/,/g;w /var/www/rad/readings.csv'
note: the awk part add unixtime, date and time, the sed part substitutes "spaces" with "commas" and writes the csv file,
unixtime (optional) will be used as a primary key in Mysql to avoid importing duplicates.
add print_rad2csv.sh to "/etc/rc.local" file:
#!/bin/sh -e
# rc.local
/bin/sh /root/print_rad2csv.sh
exit 0
results:
1548232110,2019-01-23,09:28:30,0.056840,uSv/h
1548232170,2019-01-23,09:29:30,0.073080,uSv/h
1548232290,2019-01-23,09:31:30,0.048720,uSv/h
radmon.sh
#!/bin/bash
# J305By tube conversion factor from uSv/h to CPM (CPM = uSv/h * conv)
conv=123.14709
# read last value from csv file generated by my instrument
line="$(/usr/bin/tail -n 1 /var/www/rad/readings.csv | cut --complement -c  1-31 | cut --complement -c  9-14 | sed -e 's/,/ /g')"
# calculations to get CPM from uSv/h
#echo $line
line2="$(echo "$line*$conv" | bc)"
#echo $line2
line3="$(echo $line2 | awk '{print int($1+0.5)}')"
#echo  $line3
# send data to radmon.org
user="pilovis"
password="mypwd"
exec=`wget -O /dev/null "http://radmon.org/radmon.php?function=submit&user=$user&password=$password&value=$line3&unit=CPM"
send to radmon.org the last CPM reading every minute:
crontab -e
*/1 * * * * /bin/sh /root/radmon.sh
Extra:
Import data into MySQL database:
import_csv2sql.sh
#!/bin/bash
/usr/bin/mysql -upilovis -pmypwd --local_infile=1 data -e "LOAD DATA LOCAL INFILE '/var/www/rad/readings.csv' INTO TABLE letture_radiazioni FIELDS TERMINATED BY ',' enclosed by '\
MySQL db structure
CREATE TABLE `letture_radiazioni` (
  `unix_time` bigint(20) NOT NULL,
  `date` date DEFAULT NULL,
  `time` time DEFAULT NULL,
  `value` decimal(10,6) DEFAULT NULL,
  `unit` text,
  PRIMARY KEY (`unix_time`),
  UNIQUE KEY `unix_time` (`unix_time`)
I'm planning to move from one reading for 6000 ms (one minute) to one reading for 30000 ms (30 minutes), to get more consistent data.
7 years 7 months ago - 7 years 7 months ago #4259 by pilovis
Today here in North West Italy it is snowing and the CPM readings are much higher than usual
7 years 7 months ago - 7 years 7 months ago #4261 by pilovis
A very simple web page in HTML to show your data and graphs from radmon.org
mypage.html
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<title>
</title>
<head>
<meta http-equiv="refresh" content="30" >
</head>
<body>
<font size="2">
<div align="center">
<p>
<i>this page auto refreshes every 30 seconds</i>
<p>
</font>
<font size="4">
<hr>
<b>- Current readings:</b>
<p>
<img src="http://www.radmon.org/radmon.php?function=cpmreading&user=pilovis"/> (Counts per minute)
<p>
<hr>
<p>
<center>
<form action="http://www.radmon.org/radmon.php?user=pilovis&function=graphtoday&refresh=true" method="post">
<input type="submit" value="Update graphs">
</form>
<br>
<img src="https://radmon.org/UserGraphs/pilovis/graphlasthour.png" alt="" />
<br>
<img src="https://radmon.org/UserGraphs/pilovis/graphtoday.png" />
<p>
<hr>
</center>
</font>
</body>
</html>
note: change "pilovis" with your username.
7 years 7 months ago - 7 years 7 months ago #4262 by pilovis
Next step will be to connect a GPS and a 3G USB dongles to this device, than put it in my car and start sending data/position 24 hours a day to a central database.
7 years 7 months ago #4263 by pilovis
7 years 7 months ago #4265 by mw0uzo
Ah a great thread! Thank you for posting the details and the BASH scripts and code. There will be several people interested in this information. Thank you pilovis!
Time to create page: 0.237 seconds
Solar powered Raspberry Pi 4 server stats: CPU 55% Memory 15% Swap 17% CPU temp=63.7'C Uptime 17 Days
