Connecting Geiger Counter for Arduino and Raspberry Pi to radmon.org
7 years 7 months ago - 7 years 7 months ago #4326 by pilovis
Just to improve the system and get notification every time the CPM reading goes above a certain limit.
I choosed to get notification by XMPP since I've got my own personal XMPP server, but you can easily change the code and get notification by SMS or/and by email.
To install a simple XMMP client on Raspberry do the following:
su - root
apt-get install sendxmpp
then create config file for sendxmpp:
su - root
echo "me@myjabberserver.com mypassword" >> ~/.sendxmpprc
chmod 700 ~/.sendxmpprc
cp -v ~/.sendxmpprc /etc/sendxmpprc
note: change "This email address is being protected from spambots. You need JavaScript enabled to view it." and "mypassword" with your credentials
Bash code modified (see previous posts):
#!/bin/bash
# send data to radmon.org and send notification for alarm state
# SBM-20 tube conversion factor from uSv/h to CPM
conv=361
# read last value from csv file generated by the instrument
line="$(/usr/bin/tail -n 1 /tmp/readings.csv | cut --complement -c  1-31 | cut --complement -c  9-14 | sed -e 's/,/ /g')"
# calculations to get CPM from uSv/h
line2="$(echo "$line*$conv" | bc)"
line3="$(echo $line2 | awk '{print int($1+0.5)}')"
user="my_radmon_username"
password="mypasswd"
exec=`wget -O /dev/null "http://radmon.org/radmon.php?function=submit&user=$user&password=$password&value=$line3&unit=CPM"`
/bin/sleep 5
##### alarm notification section #####
# notify alarm by XMPP if CPM > 75
alarm=75
if [ $line3 -gt $alarm ];
then
echo "Alarm CPM = "$line3 | sendxmpp -s hello me@myjabberserver.com
else
    echo "everything is normal" > /dev/null 2>&1;
fi;
4 years 5 months ago - 4 years 5 months ago #6098 by pilovis
I was finally able to power the geiger dosimeter with solar cells (12V 100W+20W).
File Attachment:
File Attachment:
File Attachment:
File Attachment:
Last edit: 4 years 5 months ago by pilovis.
Time to create page: 0.135 seconds
Solar powered Raspberry Pi 4 server stats: CPU 55% Memory 14% Swap 17% CPU temp=63.3'C Uptime 17 Days
