Conversion factors.
- ThibmoRozier
11 years 10 months ago #121
by ThibmoRozier
Conversion factors. was created by ThibmoRozier
Here we go. ^_^
Most of this topic I could recover.
Got it.
A small chart to compare tubes.
[img]https://dl.dropboxusercontent.com/u/3572198/Chart%20-%20GM%20all%20tubes.png[/img]
To save the calculations for you.. :P
0.0039Hello guys, thought this would be handy to post newly calculated conversion rates. :)
M4011:
Test info taken from here: http://tskagawa.com/?page_id=2061
Known:
Conversion rate for SBM-20 --> 0.0057
Calculations:
uranium glass bead 238U :
SBM-20 --> 290cpm * 0.0057 = 1.653µSv/h
M4011 --> 1.653µSv/h / 245cpm = 0.0067469387755102
uranium ore 238U :
SBM-20 --> 471cpm * 0.0057 = 2.6847µSv/h
M4011 --> 2.6847µSv/h / 436cpm = 0.0061575688073394
smoke detector pellet 241Am :
SBM-20 --> 896cpm * 0.0057 = 5.1072µSv/h
M4011 --> 5.1072µSv/h / 790cpm = 0.0064648101265823
lantern mantle 232Th full size:
SBM-20 --> 5253cpm * 0.0057 = 29.9421µSv/h
M4011 --> 29.9421µSv/h / 4386cpm = 0.0068267441860465
Averaging:
0.0067469387755102 + 0.0061575688073394 + 0.0064648101265823 + 0.0068267441860465 = 0.0261960618954784
0.0261960618954784 / 4 = 0.0065490154738696
0.0065490154738696 <-- rounding to 4 digits behind the dot --> 0.0066 <-- Theoretical conversion rate for the M4011 after applying maths. :)
Hope this helped out. :)
The following user(s) said Thank You: filewalker, Electrodemente
- RH Electronics
11 years 7 months ago - 11 years 7 months ago #661
by RH Electronics
http://rhelectronics.net
Replied by RH Electronics on topic Conversion factors.
Great Thimo!
I would add that using alpha/beta filter is definitely required when extracting conversion factors with this method. So I'm sure we cannot use the chart because we don't know if alpha/beta filter was used, I suppose these reading where taken without filter. If you make a practical test to extract the factor use at least thin aluminum foil between the tube and radiation sample to cut alpha and beta.
I attach electrical information for the tubes.
Last edit: 11 years 7 months ago by RH Electronics.
The following user(s) said Thank You: Frank, Electrodemente
11 years 7 months ago #666
Replied by Frank on topic Conversion factors.
This is great for the beginners, what about the M4011 tube, seems to be a common tube out here, are they not good enough to make it on this list? I don't know much about the tubes in general so would or is this model tube on the lower end of the list and not a preferred tube over the ones listed as these are perhaps better performers?
- RH Electronics
11 years 7 months ago #667
by RH Electronics
Frank, I do not speak about tube X is better than tube Y.
I speak about conversion factor number that applicable ONLY for GAMMA radiation. The diagram from the link https://dl.dropboxusercontent.com/u/3572198/Chart%20-%20GM%20all%20tubes.png is present cpm values from different sources that contains alpha/beta/gamma radiation pollution. The measurements where taken without alpha/beta filters to allow only gamma detection. So my conclusion that this diagram is not applicable to extract conversion factor numbers. You have to apply filter before you extract the factor. Usually aluminum foil is enough to filter alpha and beta.
11 years 7 months ago #669
Agree with you and wasn't really stating x against y, was just wondering why I see charts with these factors and didn't know why the tube I have here is not listed, that's all. Thank you
- RH Electronics
11 years 7 months ago #670
by RH Electronics
