Conversion factors.
11 years 7 months ago - 11 years 7 months ago #671 by ThibmoRozier
Replied by ThibmoRozier on topic Conversion factors.
Hello guys.
I have found some info..
The Beta/Gamma tube M4011 aka RS-DGM-005 aka J302
1>
Both beta and gamma radiation detetion.
Working Voltage: 380-450V
Working Current: 0,015-0,02 mA
Sensivity to Gamma Radiation: 0.1 MeV
Own Background: 0,2 Pulses/s
Working Temperature Range: -50 +60 С
Length:  88mm
Diameter: 10mm
2>
Model M4011 countertube
The detector is oxide cathode tube,coaxial cylindrical structure of thin walled(the denity of tube wall50±10cg/cm2),the Pulse application-oriented halogen tube,The ambient temperature from -40°C~55°C range that is exploring 20mR/h-120mR/hγ-ray and 100~1800 off variables/min.cm 2 softβ-ray.
Diameter: Φ10±0.5mm
Length: 90±2mm
Starting voltage:<350V
Minimum plateau rang:80v
Maximum plateau slope:10%/80v
Recommended working voltage: 380V
Maximum count rate:25times/min
Limit working voltage: 550V
Life expectancy: >1×109pulse
Last edit: 11 years 7 months ago by ThibmoRozier.
Time to create page: 0.106 seconds
Solar powered Raspberry Pi 4 server stats: CPU 55% Memory 16% Swap 17% CPU temp=63.7'C Uptime 17 Days
