SBT-11A Photographs
  • Sonarflash
  • Premium Member
  • Premium Member
9 years 1 month ago #3442 by Sonarflash
Replied by Sonarflash on topic SBT-11A Photographs
Well, I got motivated on this SBT-11A anode issue. Following Chris's example, I used several computer connector clips with bits of wire still attached. Jury-rigged two sets. One set had 3 4.7M resistors on 3 separate clips. No soldering, just twisted pairs. The three anode resistors were twisted common with another 4.7M resistor. The other set had 3 clips, their leads twisted together in a common, then 2 4.7M resistors in series to equal the previous setup. My DIY GK4 counter has an active 4.7M anode resistor on the plus terminal.
I ran each setup for about 12 minutes and took out 10 minutes of readings. Both runs produced quite similar results with an old americium-241 smoke detector button centred on the mica window's protective SS mesh.
was clips To these was connected a 4.7M resistor in series.
Time to create page: 0.114 seconds
Solar powered Raspberry Pi 4 server stats: CPU 58% Memory 15% Swap 17% CPU temp=63.3'C Uptime 17 Days
