- Introductions and FAQ
- Howtos and FAQs
- "Is it possible to work without being connected to the internet?
- Danielgeiger
- Junior Member
2 years 10 months ago #6784
by Danielgeiger
Replied by Danielgeiger on topic "Is it possible to work without being connected to the internet?
I try to install Pyradmon but it seen me this mensaje: untimeError: Bad magic number in .pyc file
2 years 10 months ago #6790
Replied by Simomax on topic "Is it possible to work without being connected to the internet?
I know nothing about pyradmon, but there is an entire section of the forum dedicated to it, here:
https://radmon.org/index.php/forum/pyradmon
. You may find an answer there. If you are using Python 3, then you could try using Py3Radmon.py from this thread here:
https://radmon.org/index.php/forum/pyradmon/1268-python3-support-for-pyradmon
. It may, or may not fix your issue.
- Danielgeiger
- Junior Member
2 years 10 months ago #6805
by Danielgeiger
I have tried to use it on Windows with Radlog software and on Linux... worse I can't get any signal to appear, I have the same configuration as the photo you showed me
2 years 10 months ago #6806
Try connecting your counter to a stereo or HiFi, or something with a AUX input. you should be able to hear the clicks from the counter with the speakers if it is working properly. Also, make sure the jumper (P100) is fitted as that is required for the audio output according to the circuit diagram.
I have also noticed a discrepancy in the circuit diagram, or I should say, diagrams. Seems there is more than one circuit diagram available for the CAJOE and of the two I have looked at, one has the pulse audio going to just one of the stereo channels, and the other diagram has both left and right connected for pulse audio. It is possible the pulse audio is just coming from one channel and the software may need the other channel. I will have a look at my CAJOE when I get home later today and see if both channels or just one is connected.
I have attached both circuit diagrams below. You can see that one has both audio channels connected, but the other just has one channel connected. If you could plug your counter into a stereo it would be easy to hear if the clicks are just coming out of one speaker.
2 years 10 months ago #6807
I have just checked my CAJOE and both audio channels are linked together. Best I can suggest for now is try and connect it to a stereo or something and make sure you can hear the clicks from the speakers.
2 years 10 months ago #6808
Replied by Bert490 on topic "Is it possible to work without being connected to the internet?
Earbuds or a headphone should be good enough for this test without needing an amplifier.
- Howtos and FAQs
Time to create page: 0.176 seconds
