Howdy
7 years 6 days ago - 7 years 6 days ago #4724 by Wukong
Replied by Wukong on topic Howdy
Seems if i run the script, it will upload 0 or 1 sample to the map before it closes.
Last edit: 7 years 6 days ago by Wukong.
7 years 6 days ago - 7 years 6 days ago #4727 by Simomax
Replied by Simomax on topic Howdy
\r\n is ascii for 'carriage return' and 'new line' So it looks to me like '19\r\n20\r\n' is the equivalent of:
19
20
Doing a quick search it appears that the error 'invalid literal for int() with base 10' is when it is reading a float value as an integer, or the variable is an integer and the data is something else. It seems strange that you get a few lines OK and boom, it breaks. Is there any way you can test with a different TTL/USB adapter? I would take a stab that the data from the GC10 is somehow being corrupted or read wrong or something. What I mean is that pyradmon is looking for an integer i.e. '19' but is receiving something different. Either some ascii character or something else that is being received by pyradmon that it doesn't like. Oh, Base 10 simply means decimal, 0 - 9. Base 7 is Octal and base 16 is HEX etc to put it into comparison.
Edit; can you fire up a terminal on your Pi and just leave it printing the cpm for some time. Check for bad characters, carriage returns or new lines that are missing. What you want is a constant stream of the CPM being printed on a new line each time and only that. If you are receiving the odd character that isn't a number that could be your issue.
Last edit: 7 years 6 days ago by Simomax.
7 years 6 days ago #4728 by Simomax
Hmm, actually I wonder if pyradmon is reading '19\r\n20\r\n' as one reading when in fact that string is actually two readings? As though it hasn't processed the carriage return and new line.
7 years 5 days ago #4736 by Wukong
Cheers, i think i understood all that.
Im getting no odd characters through terminal, that seems to work perfectly, just as you describe, each a whole number, on a new line. So i guess the problem must be in pyradmon somewhere.
7 years 5 days ago #4740 by Wukong
Bingo! Erm, thanks for all your help, but turns out its my fault entirely!
I just needed to choose netio as the protocol, in the config file, because i have a netio device. Heh.
Seems to be working just fine!
Kingston Tasmania has a rad monitor!
Nice to find a decent use for my pi zero.
The following user(s) said Thank You: mw0uzo, Simomax, FSM19
7 years 5 days ago #4745 by Simomax
That's great news! I knew with a bit of perseverance you would get it sorted, well done!
Not being familiar with pyradmon I didn't know you could choose protocols. I'll remember for the future.
Time to create page: 0.161 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 15% Swap 17% CPU temp=64.2'C Uptime 17 Days
