Howdy
7 years 6 days ago #4716 by Wukong
Replied by Wukong on topic Howdy
Thanks guys.
Unfortunately, im pretty hazy on how to use terminal with ports, not really sure what im doing!
How would I open a terminal for reading the serial data?
Yup, i got radlog running, and uploading with the gc10 (my only geiger atm), that was nice and easy. Seems like the gc10 is configured ok.
I think id better have a bit more of a read about terminal and serial data.
7 years 6 days ago - 7 years 6 days ago #4717 by Wukong
A ha! i did manage to connect through terminal, using: sudo screen /dev/ttyUSB0
Getting a nice stream of the right kind of numbers!
Still getting the same error running pyradmon.py though.
Last edit: 7 years 6 days ago by Wukong.
7 years 6 days ago #4718 by mw0uzo
Replied by mw0uzo on topic Howdy
Can you copy and paste the numbers so we can check? I'm looking for numbers like 24.5 instead of 24.
7 years 6 days ago #4719 by Simomax
Replied by Simomax on topic Howdy
I'm pretty sure the GC10 only prints whole numbers with no decimals. Both of mine work that way and I don't know of a way to get it to print decimals. I suspect the data is OK from the GC10 and the issue is with PyRadmon.py.
Having a read of the old thread it looks to be an issue with the Pi opening the serial port. Unfortunately I know little about nix and even less of Python. Could do with ThibmoRozier's input if he is about these days?
7 years 6 days ago #4722 by Wukong
Yep, it outputs whole numbers
25
24
25
26
Etc
I actually might have got the baud rate wrong.
Changed it to 9600, now pyradmon really wants to go, but can't quite manage it:
Initializing geiger communication => geiger 1
Geiger sample => geiger 1: CPM = 19 2019-09-05 12:30:00.317059
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:01.425047
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:02.532857
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:03.640507
Average result => geiger 1: CPM = 18 2019-09-05 12:30:03.640507
Connecting to server => geiger 1
Sending average sample => geiger 1: 18 CPM
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:04.748539
Server response => geiger 1: HTTP/1.1 200 OK
Waiting 30 seconds => geiger 1
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:05.855546
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:06.962765
Geiger sample => geiger 1: CPM = 18 2019-09-05 12:30:08.069434
Problem in getData procedure (disconnected USB device?) => geiger 1:
invalid literal for int() with base 10: '19\r\n20\r\n'
Exiting
7 years 6 days ago #4723 by Wukong
Ive come across similar errors in python before. Im not great with programming but i think It can't convert something into an integer. I rember those problems were easy deal with, but i have no idea where this problem is, or what "with base 10: '19\r\n20\r\n'" means.
Time to create page: 0.301 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 15% Swap 17% CPU temp=65.7'C Uptime 17 Days
