Hola from Canary Islands, Spain
9 years 5 months ago - 9 years 5 months ago #3127 by Electrodemente
:cheer:
Hi, you can call me ELECTRODEMENTE, im a Spanish man worried about the big amount of waste in form of radionucleids expend on air, ocean and earth surface.
If you agree and you want to talk about...feel free to send me a msg...
I would like to compare mesurements and learn about equiments, geiger tubes, mesurement procedures....
Thanks for reading me.
Saludos!
ElectroDemente
EDIT:
My equipment have a SBM20 Tube, a M4011 tube and I´m located on Canary Islands, Spain.
(1300 Km more or less away from the 60´s French Nulclear Aerial Test on Argel Sahara... (ARGELIA /REGGANE) and even seems too much, the test was done on air, radionucleides lives along centuries, and lot of days we suffer DUSTSTORMS from Sahara powder. (Pssst, Don´t tell nobody! hahaha)
Refs;
ON SPANISH; https://es.wikipedia.org/wiki/Anexo:Pruebas_nucleares_de_Francia
ON ENGLISH: https://en.wikipedia.org/wiki/List_of_nuclear_weapons_tests_of_France
ON FRENCH: https://fr.wikipedia.org/wiki/Liste_des_essais_nucl%C3%A9aires_fran%C3%A7ais
Other mostly unknown and semi-hidden waste:
https://en.wikipedia.org/wiki/Lists_of_nuclear_disasters_and_radioactive_incidents
Now do your accounts: Add to the well known civilian accidents+nuclear test aerial, underwater, and terrestrial ....about 1300 test+ SEE MILITARY and add it too ...
Is to be worried...and this could explain the increase of lung cases... in my humble opinion, ... so much free radionucleides running on air and food collected and imported, exported and moved from one place to other around the world in hours...
Is a real lotto.
Interesting:
http://barentsobserver.com/en/arctic/2013/08/two-nuclear-generators-missing-arctic-26-08
http://englishrussia.com/2009/01/06/abandoned-russian-polar-nuclear-lighthouses/
Map (Excuse I found only on Spanish link): http://www.foromilitar.com.ar/foro/index.php?threads/faros-nucleares-abandonados-en-las-costas-de-rusia.1265/
Last edit: 9 years 5 months ago by Electrodemente.
9 years 5 months ago #3136 by Bert490
Welcome, Elecrodemente. It will be good to finally have a station off the African coast. Dan will soon give you a password to submit data.
The following user(s) said Thank You: Electrodemente
9 years 5 months ago #3139 by mw0uzo
Welcome Electrodemente! It's all set up for you. Thanks for the donations, every bit helps cover the bills for radmon.org :)
Please use Electrodemente as the username, not ElectroDemente.
9 years 5 months ago #3140 by Electrodemente
Thanks to you, for your time and effort, mw0uzo.
I will try to contribute with the info I´ll find.
As well I will try to translate as possible to spanish the important info I could find in english or french, to open the info to a "wider audience".
I have a regular german as well, but for me is complicated to write in german ... (mostly because the verbs and declinations).
And thanks for the advice about my nick.
Best regards mw0zo,
Electrodemente.
9 years 5 months ago #3145 by mnrad
Your detector has stopped transmitting data to RadMon. Is there some problem?
9 years 5 months ago #3161 by Electrodemente
:whistle:
Sorry for that!
Technical problems.
I´m working in it!
Thanks for your interest, mnrad
Best Regards,
Saludos from Canary Islands, Spain.
Time to create page: 0.168 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 17% CPU temp=63.3'C Uptime 17 Days
