Hola from Canary Islands, Spain
9 years 5 months ago #3162 by Bert490
If you are having any difficulty, don't hesitate to ask here for advice. Some of us may have had similar problems.
The following user(s) said Thank You: Electrodemente
9 years 4 months ago #3163 by Electrodemente
:cheer:
Thanks Bert490,
I have 2 diferent problems,
1st)- The computer I use as gateway for the data, is overloaded.... So, each time the other jobs need config or mantenance, then, the computer needs shutdown or restart...
Nothing strange.
2nd)- The wifi nodeMCU from the GMC-320 Plus V5 is giving me a enormeus headache, as it choose freely their own Ip on my subnet (yes! seems so! and not from the DNS server as should be, hahhaa), ... then it produce erratically too the crash on my IPTVn (as well my provider choose on his own the ip assign and ip DNS server.... ) :oops:
As the nodeMCU was responding erratically to the terminal configuration commands i sent, I've turned it off till I have time to investigate about.
But I will manage both problems... Is only time...
:silly:
Till then: direct connection.
Best Regards!
Electrodemente
Time to create page: 0.118 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 14% Swap 17% CPU temp=64.2'C Uptime 17 Days
