The radmon.org radbox-20
11 years 8 months ago #382 by Frank
Replied by Frank on topic The radmon.org radbox-20
Looks great Dan, about what time did the switchover happen? which chart can we check it on, the possible change that is? When I remounted mine out further from the house on a pole, you could see the raise on the norm level for my area. :)
Oh, I see it now, wow, if that's it, you went from average of 55cpm's to 20cpm's on your map chart and your still in experimental mode.
11 years 8 months ago - 11 years 8 months ago #392 by mw0uzo
The detector tube has changed from an SBM-19 to an SBM-20 so the sensitivity has gone down. My station has been in experiment mode for ages, i just had a look at my long term trends in RadLog and there looks to be some detections, take a look at the max detected values. They can be seen in shared data.
Not sure if they're real or bad connection to tube. The detector was on the wall in a work area where I am busy.
Last edit: 11 years 8 months ago by mw0uzo.
11 years 8 months ago #408 by Frank
Dan, question, I just noticed that this is running audio, not a problem, but wondering, that output from that audio plug, is that just the clicking like I have now with my GMC unit that I have that use the TL-081 adapter? So I can feed this audio plug on this unit into my adapter like normal or is it strictly into the line/mic jack on the PC? I use all TL-081 adapters for all my units except for the GMC-280 that's USB. Most of my audio jacks are in use already, so I am hoping that I can just use the audio into the adapters I have in use now.
11 years 8 months ago - 11 years 8 months ago #425 by mw0uzo
Yes you should be able to use the TL-081 adaptors, connect the audio line to the 3.5mm jack. I have a similar adaptor but mine didn't appear to work as expected, so this is untested.
radbox-20 update - decided to order longer lead time parts well in advance
- SBM-20 tubes ordered
11 years 8 months ago #426 by mw0uzo
radbox-20 update
- Circuit boards ordered
11 years 8 months ago #428 by mw0uzo
Unit now available for pre-order. See the shop!
Time to create page: 0.221 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 14% Swap 18% CPU temp=62.8'C Uptime 17 Days
