The radmon.org radbox-20
11 years 6 months ago #708 by jnissen
Replied by jnissen on topic The radmon.org radbox-20
Do you have a picture of the inside? I am wondering if there is enough room for a Pi or Beagle Bone Black. I would add WiFi and then it would only need power to work. Also what is the default baud rate being used? Does the USB appear like a Serial interface. I assumed so. May pick one up if the internals are flexible.
My GMC300 can not change the baud rate and looks like I may need to pick up an alternative detector if I want the BBB to talk to it with the PyRadmon application.
11 years 6 months ago #709 by mw0uzo
Thanks for considering getting one :)
I can send you a photo when I make up the first unit, the prototype is on the wall and has all the seals fitted.
There is not enough room for a Pi or BBB. The interface is not serial, it is audio, so long cable lengths can be used.
11 years 5 months ago - 11 years 5 months ago #865 by mw0uzo
Right. Now the server is done, I have chased up where the **** these enclosures are. They won't be delivered until late March apparently, wtf. The manufacturer is a UK company, so its not like distance is a problem - how they expect their products to be used in manufacturing I have no idea. I have cancelled the order.
However, the same case is now available immediately in black. So I have ordered them instead! Had this problem not been so late in the process, I would have found a different case and a different manufacturer.
The downside is that the simple transparent/blue graphics will not show up against the black background. I have ordered some back cable glands to match the case colour.
They should be here soon, in the next few working days. Thanks for your patience.
Last edit: 11 years 5 months ago by mw0uzo.
The following user(s) said Thank You: ozycon
11 years 5 months ago #866 by ozycon
Replied by ozycon on topic The radmon.org radbox-20
Great! I was starting to wonder how much longer it would be. Btw do the units have enough room for a second tube to be added?
11 years 5 months ago #867 by mw0uzo
There isn't an option for clipping in another tube, but there is just enough room to wire another one in.
11 years 5 months ago - 11 years 5 months ago #868 by mw0uzo
The enclosures and glands will be here tomorrow! Just got off the phone with supplier, also making sure that case availaility will not be a problem for the next batch.
Time to create page: 0.204 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 18% CPU temp=63.7'C Uptime 17 Days
