Issue with Pyradmon and RH electronics IDE kit
6 years 7 months ago #4992 by docsquee
6 years 7 months ago - 6 years 7 months ago #4997 by mw0uzo
Ok what's interesting here is that if the unit's buzzer is ticking every detection, it means that the CPU has seen the pulse going into INT0/PD2 pin on the IC. As the CPU controls the buzzer. But it is not counting!
If PD2 pin had died due to excess voltage getting in by accident, then there would be no ticking from the buzzer.
That's got me scratching my head. Can you confirm that the buzzer is ticking every detection and that the display reads 0?
Last edit: 6 years 7 months ago by mw0uzo.
The following user(s) said Thank You: docsquee
6 years 7 months ago - 6 years 7 months ago #4999 by docsquee
Both the buzzer and LED1 sound/flash with each detection.
Last edit: 6 years 7 months ago by docsquee. Reason: Identify LED number.
6 years 7 months ago #5000 by docsquee
LCD has ceased working too so perhaps it's the CPU.
6 years 7 months ago #5002 by mw0uzo
Could be the CPU is locked up for some reason. You can reprogram it to try to get it working again. Contact RH for the binary image? Or get a new one sent?
Double check 5V going to display - make sure you haven't got a partial supply failure.
6 years 6 months ago #5078 by RHStation
The kit is 5V device. Are you sure you are using 5V logic level system to get data from the kit? Maybe you are using 3.3V logic level?
Time to create page: 0.183 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 14% Swap 17% CPU temp=63.3'C Uptime 17 Days
