Issue with Pyradmon and RH electronics IDE kit
6 years 8 months ago #4953 by mw0uzo
That's definitely sending 0's. I see you're using USB serial cable mygeiger mode.
ls /dev and report what ttyUSB's you have. Probably ttyUSB0?
6 years 8 months ago - 6 years 8 months ago #4954 by mw0uzo
sudo screen /dev/ttyUSB0 2400
should print serial data out to the screen. Wait for 30s. Press ctrl-a then d to close.
Last edit: 6 years 8 months ago by mw0uzo.
6 years 8 months ago #4955 by mw0uzo
If you see weird characters then try 9600 baud instead.
6 years 8 months ago #4956 by docsquee
ttyAMA0
Baud of 9600 shows 0s when using screen.
The pyradmon config file is set to a baud of 9600 and is using ttyAMA0.
It ran perfectly up until my first post of this thread.
6 years 8 months ago #4957 by mw0uzo
Ok, so the CPU in the kit is not counting the pulses from the geiger tube. There must be an electronic fault between the tube and the CPU. Usually there is a buffer of some kind, a transistor or something.
6 years 8 months ago #4958 by mw0uzo
Can you dig out or find the counter circuit diagram?
Time to create page: 0.155 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 14% Swap 17% CPU temp=63.3'C Uptime 17 Days
