RadLog v0.42 feature requests
11 years 10 months ago - 11 years 10 months ago #90 by mw0uzo
Feature requests for RadLog v0.42
- Update radmon.org logo
- Fix missing icon on Win 7
Future ideas
- Log values to APRS? - Web/serial+radio/both?
- GPS data via serial port
- Extra data, e.g. GPS, Supply voltage, Temperature
Please add to lists.
Last edit: 11 years 10 months ago by mw0uzo.
11 years 10 months ago #96 by mw0uzo
- Add MightyOhm serial data format compatibility
11 years 10 months ago #98 by corium
dating and time to png file loaded on ftp
2014.11.01 - 14:00 RadLog v0.42.png
Fukushima reactors HQ photos http://corium.cba.pl & More very important pictures http://korium.wex.pl/RadiationPics.html
11 years 10 months ago #99 by mw0uzo
Buglist from old forum
- Long term chart stuck on CPM in shared browser
- Missing icons (doh, deleted by mistake)
- Possible installer bug, Frank's install not working correctly, others OK.
- Check for proper deallocation of memory. Stable but high mem usage.
- Trend report formatting is all over the place, depending on locality. Use a datagrid instead of richtextbox presentation.
- Check operation of RadLog in non-standard install location
- Check timeout to Lite mode is cancelled if Try RadLog Professional mode was activated, then user/pass filled in afterwards
- Upload long term graph to FTP
11 years 10 months ago #100 by Frank
Replied by Frank on topic RadLog v0.42 feature requests
That last one, sounds like this site, there is even one sensor in Tyngsboro,Mass now that has these types of extra data. If you click on one of them markers, you'll see the chart he uses and the way he has it set up. I tried to get on this one, but you have to get one of the sensors he sells, that's calibrated, and get online. Which isn't a bad thing since ever sensor is built the same way so all the data is from the same type of unit. I like the way he has the breakout chart and layout... Radmon is still the best thou :) here is that site: http://www.uradmonitor.com/
11 years 10 months ago - 11 years 10 months ago #101 by Frank
"Upload long term graph to FTP" I haven't checked yet, but is this (or the others) stored locally or only sent up to Radmon?
Last edit: 11 years 10 months ago by Frank. Reason: added
Solar powered Raspberry Pi 4 server stats: CPU 58% Memory 15% Swap 18% CPU temp=66.7'C Uptime 17 Days
