RadLog v0.42 feature requests
11 years 8 months ago - 11 years 8 months ago #310 by mw0uzo
Hello everyone,
-If You can add other languages ... users of the forum will help in this.
-when RadLog is closed and reopened the graph resets ... should the graph resumption last read.
-ftp raw data, then with php or asp can be processed
Alberto
Great ideas! The function to reload the graph is present, but you have to manually do it via the Current Graph item in the log browser. It should attempt to reload first before starting the graph again. The only problem is the graph scale, if the last time RadLog was started was more than 3 hours ago, the data will be off the edge of the graph.
FTP of raw data is a very good idea.
Language support can be added, that will take a bit of work as its all 'hard coded' at the moment.
Last edit: 11 years 8 months ago by mw0uzo.
11 years 8 months ago #313 by corium
Clean air and destroy radiation, when alerts notify us :woohoo:
Hahaha :lol: :silly: :woohoo:
Fukushima reactors HQ photos http://corium.cba.pl & More very important pictures http://korium.wex.pl/RadiationPics.html
11 years 8 months ago #314 by Frank
Replied by Frank on topic RadLog v0.42 feature requests
I have thought of that to once in a while. Like today there was a windows update so I did those and had to reboot the PC, so of course the graph started all over again :( Would be cool if there was a way to pick up there it left off, if that were possible. On the long term charts, if the reboot was done fast enough, you generally won't see the flat line or some sort of gap, but today, on my other system, I rebooted and forgot to restart everything so I have a good size time lapse, geez.
11 years 8 months ago #317 by maredentro72
I thought one thing ...
The raw data via ftp are important so one does what he wants ... graphics, medium, conversioins etc ...
I saw that two other software datalogging create new files each time you start the readings. Would not it be better to create a single file for the day in question?
If I today start and stop the logging 20 times I have 20 files... It does not seem uncomfortable?
Another thing, in the end all the work of RadLog datalogging is summed up in the variety and understanding of graphics, so it would be important to be able to configure the user how many types of graphics to upload, unit of measure, dimensions, periods.
Alberto
11 years 7 months ago #550 by mw0uzo
Has anyone had any insight into posting to APRS or, APRSIS32 with or from Radlog ?? Tnx, Ric, VE7CUP
I far as I can tell, to add data to APRS, each user needs a key to be able to send data.
Are you a registered user on the website for APRSIS32? Could you ask the developer if they would be interested in receiving data from RadLog? I would be pretty cool to just be able to put in your call into RadLog and let it handle the rest. This might require a special use case for APRS though, as some checking is required to see if the user is a licensed ham.
11 years 7 months ago #552 by OM1AMJ
To APRS-IS can be sent using also PHP.
I use it on my site: http://viking.home.sk/om1amj/aprssend/
Dan, if you want I can send you my PHP code with passcode verification.
Time to create page: 0.193 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 13% Swap 17% CPU temp=58.4'C Uptime 17 Days
