Novice Questions
7 years 6 months ago - 7 years 6 months ago #4364
by GetSirius
Replied by GetSirius on topic Novice Questions
Hello, I have two additional questions.
GPS, what does this do? I assume track position of course. How is this presented? Does it automatically update the RadLog software position? Is location recorded in the RawData.txt file? Is there an easy way to map data should I run RadLog in a vehicle? Can I use something like this: https://www.amazon.com/dp/B073P3Y48Q/?coliid=I27A12T12809PG ?
Two instances? Can I run RadLog two times on the same computer and use two different geiger counters? It seems like the settings would be mixed up between the two. Do I need to install RadLog in two different directories?
Hmm, nine question marks for two questions.. Thank you for any help offered!
siriusly, Chuck
siriusly, Chuck
Last edit: 7 years 6 months ago by GetSirius.
7 years 6 months ago #4365
Replied by mw0uzo on topic Novice Questions
Yes GPS updates your location each time a value is uploaded. There is no presentation for journeys yet, it has not been an important feature so only limited functionality is available. I went back to do some more work on it, then I found Windows 10 new serial drivers broke my GPS stick. Mine was a UBlox something. I do not know if that device you linked will work, that is a UBlox too.
Yes you can run two at a time. The 'hidden' data directory is per install, this contains some settings. The main data folder is in your User folder. There is no option to change its location, so maybe you might have to run the program as a different user. Give it a try to see what happens, I have not thought to try this.
Time to create page: 0.116 seconds
