radmon.org Solar Power experiments
6 years 10 months ago #4865 by mw0uzo
radmon.org has been up and down today due to moving the server to something that has a chance of being solar powered. The main server consumes 200W continuously even with all the backup disks removed.
So radmon.org has moved to a computer that draws about 60W. This isn't very efficient as its run from an inverter. Ideally I need to find or acquire a large laptop with two disk bays to turn into a low power server.
radmon.org will be intermittent and slow while I unpack some large archives and do some experimentation.
I've got about 80Ah of battery storage, this isn't enough to power the server all night, but with the help of a power supply I can give grid power at night and run off the sun during the day. That's the plan anyway.
6 years 10 months ago #4866 by mw0uzo
The server ran out of disk space overnight due to a large file being larger than it should have been. Server working now.
6 years 10 months ago #4867 by mw0uzo
radmon.org will be up and down as I increase installed memory and import the radmon.org email server
6 years 10 months ago - 6 years 10 months ago #4868 by mw0uzo
Memory upgrade successful and email server import successful.
Tests with low memory and slow hard disk indicate that it is possible to run radmon.org server on a lower power system. In fact, I think it will run great on a RPi4 4Gb.
Current system draw is 60W not including inverter loss, so maybe total 100W.
With Rpi4 this could be reduced to <25W, with a DC-DC converter for a power supply. 25W would run all year round and leave plenty of excess juice in the batteries.
Last edit: 6 years 10 months ago by mw0uzo.
6 years 10 months ago #4869 by FSM19
Did notice one brief outage yesterday, but then I had one as well due to bad weather affecting the G4.
6 years 10 months ago #4870 by GetSirius
Thank you for the updates. I was wondering if there were problems, or something else going on.
Time to create page: 0.186 seconds
Solar powered Raspberry Pi 4 server stats: CPU 65% Memory 15% Swap 17% CPU temp=62.8'C Uptime 17 Days
