radmon.org testing new server!
11 years 6 months ago #794
Replied by mw0uzo on topic radmon.org testing new server!
Ok intense file activity showed up a bad HD in the backup set, so server was up and down while I removed it from the system. Glad this showed up now and not later, and it wasn't the main system disk!
Also completing backups onto other disks, discovered the 'nice' command so now the operations aren't slowing the server.
The following user(s) said Thank You: tcall
11 years 6 months ago #796
Had to reboot and force fsck across the working disks. All OK now.
The following user(s) said Thank You: ThibmoRozier, tcall
11 years 6 months ago #801
Well today has been a busy day working on the server. Replaced the bad disks, backed up to them and configured the backups to be bootable and GRUB'd. Did some work to make it quieter, graphics card without fan, fan controller running case fans on low speed. Got some other services partially working, still quite a bit of fiddling to do. Almost got Shared Data working again.
I'm pretty confident that the server will be alive when I check it tomorrow morning. Ahem.
11 years 6 months ago #803
Ok.... So about an hours worth of downtime today due to something wrong. I fixed another problem with the backups. Cron does not execute commands exactly like the bash shell does!!! I made some modifications and tested the backups again earlier today and they have actually worked properly ... at last. Seventeenth time lucky?
Now, can I get this Shared Data and email alerts finally working...
11 years 6 months ago #807
Replied by Frank on topic radmon.org testing new server!
Geez Dan, you have had your hands full there !! And worse, I was still using the link I had all along and haven't seen anything posted and nothing from you either, was thinking the worse
Then just a short time ago, the RSS feed stated that Marc had posted something and there was a link in it and I clicked on it and just realized that its on another one now. I was behind the whole time and had no idea it address had been switched and missed out on 4 days of your postings, feel bad now. At this time, it came up pretty fast unlike it was a few days ago, slow load and drawing time. Glad to see progress moving along, hang in there ! and I will be on this one for now on.
11 years 6 months ago #809
Hey Frank, wb
Yes, that websitehome address is from the early days of the new site. And probably would have given you weird problems with the forum.
Glad to hear the website is working quicker, that means the current solution to the hosting problem is the way forward for cost effective operations. I am glad a solution has been found, I was worried for a bit there!
Time to create page: 0.248 seconds
