radmon.org testing new server!
11 years 6 months ago #822 by mw0uzo
All I need next is the mobo to have bad caps...
Don't tempt fate :unsure:
Luckily this week has been a slow work week, so had plenty of time to get this damn thing sorted out. Seems to be stable again now. I can only pray that it stays alive overnight.
11 years 6 months ago #823 by Frank
I had hoped with the plea for help would have boosted efforts on your and gotten you closer to perhaps getting a new PC.. :unsure:
11 years 6 months ago #824 by mw0uzo
Bah! This time 'BUG: Soft CPU lockup error'
This time is was only at 8:10am, about an hour ago.
I am going to remove the CPU cooler, clean and reapply paste and set a slight underclock.
11 years 6 months ago - 11 years 6 months ago #825 by mw0uzo
Ok new paste installed, the old stuff didn't look like it had aged well at all. Cooler with copper core and more metal. Underclock to 150Mhz from 166Mhz. If this isn't stable now, then I will have to change the mobo. I have an Intel board left and a few P4 and celeron D processors and coolers in a drawer, so not at the end of the road yet. Luckily linux doesn't complain much about drastic changes of hardware :lol:
Last edit: 11 years 6 months ago by mw0uzo.
11 years 6 months ago #826 by mw0uzo
Might have found another source of problem, the IEC power cable was loose and might have a questionalble contact. Moving it around caused a reboot!
11 years 6 months ago #827 by mw0uzo
Server has been up all day without issue. Hopefully it will survive the night? Please?
If not, I have prepared an Intel mobo with P4 2.4Ghz Northwood. I tested the RAM stick that came out of the server and it showed problems, which disappeared after cleaning the edges with contact cleaner. Must have been a thin layer of oxide leached through the gold causing bad/intermittent contact. That should have shown up in memtest but it didn't. I probably didnt leave it going long enough. The ethernet interface has not been recognised (bah) so I will have to fix that if possible. Fun.
Time to create page: 0.213 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 16% Swap 18% CPU temp=67.2'C Uptime 17 Days
