8 years 9 months ago #3729 by jhackeur
Hello all!
I need to get your help about my new PyRadmon configuration...
I get this error message continously:
(see the complete logs in attached)
Do you have somes idea ?
Thanks
8 years 9 months ago #3730 by ThibmoRozier
It can take up to 30 seconds to have a first sample.
But could you share your config without username/password?
8 years 9 months ago - 8 years 9 months ago #3731 by jhackeur
Of course, config attached.
I try again, wait 5 minutes, but nothing...
Last edit: 8 years 9 months ago by jhackeur. Reason: edit attached file
8 years 9 months ago #3733 by James_Gy
Looking at your config the speed looks like it could be set too high, or does your Geiger communicate at 115200? Try changing the speed to 9600.
8 years 9 months ago #3734 by jhackeur
Yes 115200 is the default baud rate on my counter (GMC320+). I try to force with 9600bps but same issue.
Not so easy unfortunately :(
8 years 9 months ago - 8 years 9 months ago #3735 by ThibmoRozier
Let's have a good look at their docs, shall we? :)
http://www.gqelectronicsllc.com/download/GQ-RFC1201.txt
You set the protocol to mygeiger, this is wrong. For GMC this must be gmc.
This has to do with how the software collects values.
With mygeiger the software waits for a value to arrive.
With gmc the software sends a command to the get the value from the device.
Last edit: 8 years 9 months ago by ThibmoRozier.
The following user(s) said Thank You: jhackeur
Time to create page: 0.207 seconds
Solar powered Raspberry Pi 4 server stats: CPU 62% Memory 14% Swap 17% CPU temp=63.3'C Uptime 17 Days
