7 years 7 months ago - 7 years 7 months ago #4246
by pilovis
Replied by pilovis on topic PyRadmon install and set up on Raspberry Pi (Wheezy Raspbian)
I think I've found the problem.
I first downloaded the script on the "/root" directory and launched it as a root user, the program created the config.txt file in the "/root" directory, but when I launched the script at startup, it doesnt matter if it was launched as a root user, it created another config.txt file in the main root "/", I was unaware of that and so I did not configured the other "/config.txt" file, obviously that created the problem.
I would suggest you the have a fixed position for the configuration file (ex.: /etc/pyradmon/config.txt).
Thanks for your great script!
7 years 7 months ago - 7 years 7 months ago #4247
by pilovis
Also, I noticed that I have the log file in the "/" main root (or in "/root" when I launch it in foreground).
This is not good for Raspberry or for other embedded devices without a real Hard Disk, having a file on the SD card that is overwritten every 30 seconds can quickly wear-out the SD card or corrupt the filesystem in case of power outages.
I changed the log file position to an external mount: /mnt/sda1 (USB flash drive needed).
# Set logger default info
logging.basicConfig(filename = "/mnt/sda1/pyradmon_log.log", filemode = "a",
format = "%(asctime)s - %(name)s - %(levelname)s - %(message)s",
datefmt = "%d/%m/%Y %H:%M:%S %p")
logger = logging.getLogger("PyRadmon (Without audio)")
logger.setLevel(logging.DEBUG)
- ThibmoRozier
7 years 7 months ago #4248
by ThibmoRozier
Or just give me some time to work on a fix.
The way I made this stuff is a bit wonky and can be improved, which is what I am working on during my spare time.
The following user(s) said Thank You: pilovis
7 years 7 months ago - 7 years 7 months ago #4249
by pilovis
I think it's just a matter to do this:
1) create the config directory:
2) edit the python script
and change this line:
to:
3) if it's not the first run, copy your current configuration file to "/etc/pyradmon" directory:
Launch the script as root user.
that's all.
Thanks again for your nice script.
sudo mkdir /etc/pyradmon/2) edit the python script
nano PyRadmon.pyand change this line:
self.CONFIGFILE = "config.txt"to:
self.CONFIGFILE = "/etc/pyradmon/config.txt"3) if it's not the first run, copy your current configuration file to "/etc/pyradmon" directory:
sudo cp /config.txt /etc/pyradmon/config.txtLaunch the script as root user.
that's all.
7 years 7 months ago - 7 years 7 months ago #4250
by pilovis
Just to help other people having my same hardware and wanting to take part to this project.
I'm using this board:
https://www.cooking-hacks.com/documentation/tutorials/geiger-counter-radiation-sensor-board-arduino-raspberry-pi-tutorial
with Raspberry Pi to Arduino Shield Connection Bridge.
The serial port of this device (Raspberry+Arduino bridge+sensor board) is: /dev/ttyAMA0
7 years 7 months ago - 7 years 7 months ago #4251
by pilovis
To completely disable logging (higly suggested for embedded devices like Raspberry), you need to do this modification on the script:
logging.basicConfig(filename = "pyradmon_log.log", filemode = "a",
#logger.setLevel(logging.DEBUG)
logger.setLevel(logging.NOTSET)
Time to create page: 0.431 seconds
