8 years 9 months ago #3736
by jhackeur
Replied by jhackeur on topic PyRadmon install and set up on Raspberry Pi (Wheezy Raspbian)
My bad.... Indeed, working fine now!
Thanks !!
Thanks !!
7 years 8 months ago #4229
by jnissen
Transitioned to a Raspberry Pi Model 3B. The WiFi seems to be significantly more stable with both 2.4GHz and 5GHz bands supported. The good news is the Python program transitioned without any edits at all.
7 years 7 months ago #4242
by pilovis
Replied by pilovis on topic PyRadmon install and set up on Raspberry Pi (Wheezy Raspbian)
Tested on Raspberry Pi1 model B, if you launch it on foreground (/usr/bin/python /root/PyRadmon.py), it works,
but if you launch it in background (/usr/bin/python /root/PyRadmon.py > /dev/null 2>&1 &), the program stops sending any data and dies after a while.
Also if you launch it on startup (/etc/rc.local), the program stays in background, but it does not send data at all.
- ThibmoRozier
7 years 7 months ago - 7 years 7 months ago #4243
by ThibmoRozier
That's a rather odd way of running stuff on the background..
Maybe you should look into services. Not sure what you have, but look at either SystemD service scripts or use the good old /etc/init.d/ script
Let me have a look..
Last edit: 7 years 7 months ago by ThibmoRozier.
7 years 7 months ago #4244
by pilovis
It seems I have found a solution:
crontab -e
@reboot /usr/bin/python /root/PyRadmon.py > /dev/null 2>&1
crontab -e
7 years 7 months ago - 7 years 7 months ago #4245
by pilovis
No way, it doesn't work, it only works if you launch it in foreground, it doesn't matter if you launch it as a service, from /etc/rc.local or from crontab @startup, it simply dies after a few seconds.
I tested both, 1.2.0 and 1.3.0 versions.
Time to create page: 0.198 seconds
