SW problems?
5 years 2 months ago - 5 years 2 months ago #5802 by mw0uzo
Replied by mw0uzo on topic SW problems?
Settings > 'UnBloat - removes Map map tab'
Then restart RadLog for maximum memory savings
Last edit: 5 years 2 months ago by mw0uzo.
5 years 2 months ago #5803 by mw0uzo
Ok I got my counter working - the SBM20 is dead!
SBM19 fitted in place. Microphone volume level set to 70, which gives a peak on the audio pulse analysis graph of approx 0.7
5 years 2 months ago #5805 by bzk
Replied by bzk on topic SW problems?
Solved. The problem was due to the maps. Now cpu to 2 percent. I will more precise this evening.
5 years 2 months ago #5806 by Bert490
Replied by Bert490 on topic SW problems?
OK, I found the setting in Radlog now.  Mine is also at the default counting period of 30 sec and submission 60.  You can check network usage in Task Manager, by sorting the table by Network usage or by CPU usage.
5 years 2 months ago - 5 years 2 months ago #5807 by mw0uzo
Ok thanks for the update bzk - I will check the old google maps script to be sure it hasn't been tampered with. Also I might reduce the frequuency of the map update as it needs to be retired and isn't that useful in the application itself. This will reduce CPU and network load when the map is enabled.
5 years 2 months ago - 5 years 2 months ago #5809 by mw0uzo
Ok I have changed the map update period to 60s. bzk - can you re enable the map tab on the slowest computer and see if the problem has gone away?
Time to create page: 0.172 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 17% CPU temp=62.8'C Uptime 17 Days
