Gamma Spectroscopy
Detecting K-40 in bananas with Radiocode RC103
1 year 5 months ago - 1 year 5 months ago #7253
Replied by Simomax on topic Detecting K-40 in bananas with Radiocode RC103
It has never been an issue for me (stopping the accumulation after so long.) I'm curious to know what advantage a, say, 7 day (168 hours) accumulation has over a 175 hour accumulation. I have always thought that a longer accumulation would always be better than a shorter one. For instance, Last night I was re-sampling some Sr-90. It's fairly active, so I wanted around 3 hours, or more. I forgot about it, went to bed and woke up to a 12 hour accumulation, which is much better than the 3 hour I had intended. Don't get me wrong though, I'm not saying what you are trying to do is wrong or anything. I just struggle to see the issue.
After looking a little more it seems there is absolutely no way to automate this within the Radiacode apps (PC/Android - I assume the same with iOS.) However I did find some tools that may assist you, and looks to have some conversion tool for converting the spectra into ANSI N42 spec for use in InterSpec: https://github.com/ckuethe/radiacode-tools and also this here may help, or may not: https://github.com/cdump/radiacode Another method may be using something like AutoHotkey to save the XML after a certain length of time. I have looked a little at this, and I think it could only be exported as the XML as this generates a filename based on the current time/date, but saving to the library within the software seems to default to the last spectrum save name, so would most likely overwrite the perviously stored spectrum, or just stop at the 'do you want to overwrite...' dialog.
As the Radiacode accumulates the spectrum on the device itself, it would require the Radiacode to be connected to the software constantly in order to facilitate saving of the spectrum. This isn't something I generally do and just tuck the Radiacode and source away in a corner of my office and let it get on with it. I'll connect with the Andriod app (over bluetooth) to check the spectrum occasionally, then when complete, I'll plug the Radiacode into my PC, save the spectrum and reset it as necessary.
1 year 5 months ago #7256
Replied by ChrisLX200 on topic Detecting K-40 in bananas with Radiocode RC103
I like to be precise in my data captures, useful for comparative studies. If something changes (device deterioration, temperature/enviroment, sample degrading over time, whatever..) I can compare results better if the aquisition times are similar.
Thanks for your github info. I uploaded an xml file from Becqmoni to my assistant, it has examined the contents and provided code to translate it to the format InterSpec uses. This can be automated with a couple of tweaks. I think I mentioned it before but BecqMoni seems to have an issue clearing the previous spectrum data from the 103's memory prior to starting a new capture. My only solution thus far is to use Radiacode software to clear data and start a new capture, then swap to BecqMoni to continue. Looking for a better option.
1 year 5 months ago #7258
That's fair enough. I'm literally just testing samples to see what they are, and if they are what I suspect they are. I have a handful of sources that came with vague descriptions, such as '10g dried and screened natural soil from a lawn between the villages Gauern and Wolfersdorf in the uranium mining area Ronneburg.' and 'Thoriated cotton - This was supposedly found in a jar similar to a mason jar in some old mine, I think in the UK.' So is really just testing to see what kind of emitter they are.
The spectrum can on reset on the device itself, or are you looking for an automated option?
1 year 5 months ago - 1 year 5 months ago #7261
Yes, I want click 'n go after setting my desired capture time. I don't want to be sat watching it as I'm usually busy doing something else and will surely forget to stop it manually. I didn't know about the abilty to clear memory via the device menu, I should have guessed but I'll look now. I would have to remove the 103 from the shield anyway and could reset it that way for a new sample.
As an aside, I had a 'discussion' with my assistant as to why it won't interact using voice via the PC interface but will via smartphone - unless you move to the Pro level at extortionate cost.The explanation offered was that the smartphone uses built-in voice recognition whereas a PC (Windows) has no such mechanism and thus processing has to be done on their servers. I said this was still unreasonable and my comments have been returned to the system managers for comment.
Last edit: 1 year 5 months ago by ChrisLX200.
1 year 5 months ago #7265
To reset the spectrum on the device, go to the spectrum mode, so it is showing the spectrum and hold the down button for a couple of seconds, then use the single big button to select 'yes' then hold the big button. That should restart the accumulation. I think you can assign the buttons using the Radiacode PC or phone software, so may be different. You can certainly do it through the menus.
I agree, that price is crazy. I'd be interested in hearing any reply you get from them. I'd be surprised if you did though.
1 year 5 months ago #7269
Time to create page: 0.265 seconds
