11 years 6 months ago #772
by jnissen
OK it's acting a bit strange. Not sure but I can run it consecutive times and get different responses for the detector model. See below:
Reading configuration:
User name configured
Password configured
Serial port name configured
Serial port speed configured
Protocol configured
Protocol configured
Using GMC protocol for 1 => geiger 1
Gathering data started => geiger 1
Initializing GMC protocol communication => geiger 1
Found GMC-compatible device, version => geiger 1: GMC-300Re 2.36�
Please note data will be acquired once per 5 seconds => geiger 1
Unit shows time as => geiger 1: �
Problem in getData procedure (disconnected USB device?) => geiger 1:
local variable 'i' referenced before assignment
Exiting
Waiting and reap threads
You can see the special characters at the end of the line seem to be interpreted correctly depending on how many times I run it. Sometimes looks OK other times not.
Password configured
Protocol configured
Protocol configured
Exiting
- ThibmoRozier
11 years 6 months ago #774
by ThibmoRozier
Hmm... Oke...
I'll see what I can do about that.
Password configured
Protocol configured
Protocol configured
Exiting
Hmm... Oke...
11 years 6 months ago #775
by jnissen
I'm going to move on to another detector at this point. I tried a number of alternatives as well as your Pyradmon software and it seems the trouble is with some dropped bits at 56KBaud and the PL2303 driver. I tried to communicate with an alternative device that uses this same chip and if the baud rate is reasonable (like 19K or below) it seems to work just fine with the BBB. At this point I will try to sell my GMC-300 fixed baud unit and see if I can get a GMC-320+ with programmable baud rate. If there were a Wifi enabled unit I would go with that! My goal was to place the unit outside and WiFi communicate with it.
- ThibmoRozier
11 years 6 months ago - 11 years 6 months ago #776
by ThibmoRozier
I now have a little bit of debugging going on.
Oh and perhaps, you should try the geiger counter made by Dan.
It should work just fine with PyRadmon.
Welll... Please do try one last thing(For future users?)I'm going to move on to another detector at this point. I tried a number of alternatives as well as your Pyradmon software and it seems the trouble is with some dropped bits at 56KBaud and the PL2303 driver. I tried to communicate with an alternative device that uses this same chip and if the baud rate is reasonable (like 19K or below) it seems to work just fine with the BBB. At this point I will try to sell my GMC-300 fixed baud unit and see if I can get a GMC-320+ with programmable baud rate. If there were a Wifi enabled unit I would go with that! My goal was to place the unit outside and WiFi communicate with it.
class gmc(baseGeigerCommunication):
def initCommunication(self):
print "Initializing GMC protocol communication => geiger 1\r\n"
# get firmware version
response=self.sendCommand("< GETVER >>")
if len(response)>0:
print "Found GMC-compatible device, version => geiger 1: ", response, "\r\n"
# get serial number
# serialnum=self.sendCommand("<GETSERIAL>>")
# serialnum.int=struct.unpack('!1H', serialnum(7))[0]
# print "Device Serial Number is: ", serialnum.int
# disable heartbeat, we will request data from script
self.sendCommand("< HEARTBEAT0 >>")
print "Please note data will be acquired once per 5 seconds => geiger 1\r\n"
# update the device time
unitTime=self.sendCommand("< GETDATETIME >>")
time.sleep(0.5)# just to ensure all CPM bytes are in serial port buffer
print "Unit shows time as => geiger 1: ", unitTime, "\r\n"
# self.sendCommand("<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>")
# print "<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>"
else:
print "No response from device => geiger 1\r\n"
self.stop()
sys.exit(1)
def getData(self):
cpm=-1
try:
# wait, we want sample every 30s
for i in range(0,3):
time.sleep(1)
# send request
response=self.sendCommand("< GETCPM >>")
# wait for data
time.sleep(0.5) # just to ensure all CPM bytes are in serial port buffer
if len(response)==2:
# convert bytes to 16 bit int
cpm=cpm + ord(response[0])*256+ord(response[1])
else:
edata=""
for i in range(1,len(response)):
edata = edata + ord(response[0])*256+ord(response[i])
print "Unknown response to CPM request, device is not GMC-compatible? => geiger 1\r\n"
print "Data recieved was: ",str(edata),"\r\n"
except Exception as e:
print "\r\nProblem in getData procedure (disconnected USB device?) => geiger 1:\r\n\t",str(e),"\r\nExiting\r\n"
self.stop()
sys.exit(1)
utcTime=datetime.datetime.utcnow()
data=[cpm, utcTime]
return dataOh and perhaps, you should try the geiger counter made by Dan.
Last edit: 11 years 6 months ago by ThibmoRozier.
11 years 6 months ago - 11 years 6 months ago #777
by jnissen
Humm well it's been running about seven minutes... fingers crossed.
It did report this but still works...
Data recieved was:
Geiger sample => geiger 1: CPM = -1 2015-03-01 03:58:44.750654
Geiger sample => geiger 1: CPM = 12 2015-03-01 03:58:48.758551
Geiger sample => geiger 1: CPM = 13 2015-03-01 03:58:52.768874
Never saw it report that before. it seems to keep running and the average is only slightly lower as a result. Perhaps the thing was never responding to the request at times? I will let it run and see how it does.
UPDATE:
About 20 minutes so far. I do see errors, but it gets through them.
Geiger sample => geiger 1: CPM = 15 2015-03-01 03:57:16.496798
Geiger sample => geiger 1: CPM = 13 2015-03-01 03:57:20.506366
Geiger sample => geiger 1: CPM = 15 2015-03-01 03:57:24.518782
Geiger sample => geiger 1: CPM = 15 2015-03-01 03:57:28.529968
Data recieved was:
Geiger sample => geiger 1: CPM = -1 2015-03-01 03:57:32.544654
Data recieved was:
Geiger sample => geiger 1: CPM = -1 2015-03-01 03:57:36.558507
Geiger sample => geiger 1: CPM = 18 2015-03-01 03:57:40.567113
Average result => geiger 1: CPM = 11 2015-03-01 03:57:40.567113
Connecting to server => geiger 1
Sending average sample => geiger 1: 11 CPM
Server response => geiger 1: HTTP/1.1 200 OK
Waiting 30 seconds => geiger 1
Geiger sample => geiger 1: CPM = 17 2015-03-01 03:57:44.578701
Data recieved was:
Geiger sample => geiger 1: CPM = -1 2015-03-01 03:57:48.592302
Geiger sample => geiger 1: CPM = 20 2015-03-01 03:57:52.601759
Geiger sample => geiger 1: CPM = 19 2015-03-01 03:57:56.612825
Geiger sample => geiger 1: CPM = 20 2015-03-01 03:58:00.624583
Geiger sample => geiger 1: CPM = 22 2015-03-01 03:58:04.635998
Geiger sample => geiger 1: CPM = 22 2015-03-01 03:58:08.647235
Geiger sample => geiger 1: CPM = 20 2015-03-01 03:58:12.658822
Average result => geiger 1: CPM = 17 2015-03-01 03:58:12.658822
Sending average sample => geiger 1: 17 CPM
Geiger sample => geiger 1: CPM = 20 2015-03-01 03:58:16.670564
Geiger sample => geiger 1: CPM = 21 2015-03-01 03:58:20.680302
Geiger sample => geiger 1: CPM = 18 2015-03-01 03:58:24.691723
Geiger sample => geiger 1: CPM = 20 2015-03-01 03:58:28.702770
Geiger sample => geiger 1: CPM = 17 2015-03-01 03:58:32.713823
This was the worst of it. Most of the transactions are normal but for whatever reason the above it was going crazy with errors every few seconds. I will let it run all night and see if the website map is updating. I will let you all know how it goes.
Data recieved was:
UPDATE:
Data recieved was:
Data recieved was:
Data recieved was:
Last edit: 11 years 6 months ago by jnissen.
- ThibmoRozier
11 years 6 months ago - 11 years 6 months ago #779
by ThibmoRozier
At least it's something... Now I have to work with that data...
So it seems to not enjoy the method of sending data...
The retrieval is even worse... Gosh.
It keeps giving data waaaay too much.. :/
Every 4 seconds it seems... How does your class Main look like?
//EDIT:
@Dan, could you please show how you managed to fix this, I am starting to get a headache. :/
I really want to fix this issue.
Then a little try from my side... To bypass the sendCommand definition...
The GMC class:
The Main class(//NOTE I changed "def" to "class"):
//EDIT:
The GMC class:
self.serialPort.flushInput()
self.serialPort.write("< GETVER >>")
# assume that device responds within 1s
time.sleep(1)
response=""
while (self.serialPort.inWaiting()>0 and self.stopwork==0):
response = response + self.serialPort.read()
# response=self.sendCommand("< GETVER >>")
if len(response)>0:
# get serial number
self.serialPort.write("< HEARTBEAT0 >>")
# self.sendCommand("< HEARTBEAT0 >>")
self.serialPort.write("< GETDATETIME >>")
time.sleep(1)
response=""
unitTime = unitTime + self.serialPort.read()
# unitTime=self.sendCommand("< GETDATETIME >>")
else:
self.stop()
sys.exit(1)
def getData(self):
cpm=-1
try:
time.sleep(1)
# send request
self.serialPort.write("< GETCPM >>")
time.sleep(1)
response=""
# response=self.sendCommand("< GETCPM >>")
# wait for data
cpm = cpm + ord(response[0])*256+ord(response[1])
elif len(response) > 2:
edata=""
cpm = int( ( float(cpm) / ( len(response) - 1 ) ) +0.5)
else:
edata=""
self.stop()
sys.exit(1)
data=[cpm, utcTime]
return dataThe Main class(//NOTE I changed "def" to "class"):
class main():
# main loop is in while loop
# check if file exists, if not, create one and exit
if (os.path.isfile("config.txt")==0):
print "\tNo configuration file, creating default one.\r\n\t"
try:
f = open("config.txt", 'w')
f.write("# Parameter names are not case-sensitive\r\n")
f.write("# Parameter values are case-sensitive\r\n")
f.write("user=test_user\r\n")
f.write("password=test_password\r\n")
f.write("# Port is usually /dev/ttyUSBx in Linux and COMx in Windows\r\n")
f.write("serialport=/dev/ttyUSB0\r\n")
f.write("speed=2400\r\n")
f.write("# Protocols: demo, mygeiger, gmc, netio, audio\r\n")
f.write("protocol=demo\r\n")
f.write("# In case of audio, input the device number here, default is 0.\r\n")
p = pyaudio.PyAudio()
info = p.get_host_api_info_by_index(0)
#for each audio device, determine if is an input or an output and add it to the appropriate list and dictionary
for i in range (0,info.get('deviceCount')):
if p.get_device_info_by_host_api_device_index(0,i).get('maxInputChannels')>0:
f.write("# %d - %s \r\n"%(i,p.get_device_info_by_host_api_device_index(0,i).get('name')))
f.write("device=0\r\n")
print "\tPlease open config.txt file using text editor and update configuration.\r\n"
print "\tFailed to create configuration file\r\n\t",str(e)
finally:
time.sleep(1)
p.terminate()
f.close()
sys.exit(1)
else:
# create and read configuration data
cfg=config()
cfg.readConfig()
# create geiger communication object
if cfg.protocol==config.MYGEIGER:
print "Using myGeiger protocol for 1 => geiger 1\r\n"
geigerCommunication=myGeiger(cfg)
elif cfg.protocol==config.DEMO:
print "Using Demo mode for 1 => geiger 1\r\n"
geigerCommunication=Demo(cfg)
elif cfg.protocol==config.GMC:
print "Using GMC protocol for 1 => geiger 1\r\n"
geigerCommunication=gmc(cfg)
elif cfg.protocol==config.NETIO:
print "Using NetIO protocol for 1 => geiger 1\r\n"
geigerCommunication=netio(cfg)
elif cfg.protocol==config.AUDIO:
print "Using audio protocol for 1 => geiger 1\r\n"
geigerCommunication = audioCommunication(cfg)
else:
print "Unknown protocol configured, can't run => geiger 1\r\n"
sys.exit(1)
try:
# create web server communication object
webService=webCommunication(cfg)
# start measuring thread
geigerCommunication.start()
# Now send data to web site every 30 seconds
while(geigerCommunication.is_running==1):
sample=geigerCommunication.getResult()
if sample[0]!=-1:
# sample is valid, CPM !=-1
print "Average result => geiger 1:\tCPM =",sample[0],"\t",str(sample[1]),"\r\n"
try:
webService.sendSample(sample)
print "Error communicating server => geiger 1:\r\n\t", str(e),"\r\n"
print "Waiting 30 seconds => geiger 1\r\n"
# Waiting 60x0.5 seconds,
# it has a better response when CTRL+C is used,
# might be changed in future
for i in range(0,60):
time.sleep(0.5)
else:
print "No samples in queue, waiting 5 seconds => geiger 1\r\n"
for i in range(0,5):
time.sleep(1)
continue
except KeyboardInterrupt as e:
print "\r\nCTRL+C pressed, exiting program\r\n\t", str(e), "\r\n"
except SystemExit:
print "\r\nSystem exit\r\n\t",str(e),"\r\n"
print "\r\nUnhandled error\r\n\t",str(e),"\r\n"
geigerCommunication.stop()
# Threading fix
print "Waiting and reap threads"
time.sleep(1)
for numThread in threading.enumerate():
if numThread.isDaemon(): continue
if numThread.getName() == 'MainThread': continue
print "Stopping alive thread: ", numThread.getName(), "\r\n\t"
numThread.stop()
time.sleep(1)
sys.exit(0)
if __name__ == '__main__':
main()
Time to create page: 0.214 seconds
